Old 07-03-2019, 11:31 AM   #1
The Rocknrod
Too Cool For School
The Rocknrod's Avatar
Fuel Line Size Pump to Carb
What is the consensus on the size of fuel line I should use from the fuel pump (mechanical) to the Carb. Using a 625 cfm Street Demon. Right now Iím all set up for a 3/8 tube, but I was thinking of maybe using a 5/16Ē tube instead. Blueprint Engines 350.
The fuel pressure would be the same but the volume might be more? Maybe that is over-thinking, just raising a float.
I donít know thatís why Iím asking what the general thoughts are on the subject. What do you think?
Master Chief, US Navy, Retired - He ain't no drag Papa's got a brand new bag
1964 C10 Step-side Short Bed - In Progress
2009 2500HD Duramax LTZ
1948 GMC Panel
1956 Big Window Stepside
1953 5 Window Chevy Stepside
New Seat Foam for Bench Seats?
Old 07-03-2019, 11:52 AM   #2
kwmech
Re: Fuel Line Size Pump to Carb
Why do you think a smaller line will give you more volume? GM went to 3/8 for a reason on the V8. 5/16 was for the 6 cyl. Pressure will be the same regardless.
Had this happen to me at the plumbing store a couple of years back. I was looking for some fittings for a gravity water system I was installing. 4'' pvc down the hill from my storage tanks. I needed to end up at a hose bib with 1'' to the valve with a few Ts underground. Guy commented that by doing that I should have 4 times the pressure. I just looked at him and said you're fired. I got the weirdest look from him.
Old 07-03-2019, 11:54 AM   #3
The Rocknrod
Too Cool For School
More volume on the larger line. Maybe I didnt write it correctly on my first post.
1948 GMC Panel
Old 07-03-2019, 12:31 PM   #4
rpmerf
rpmerf's Avatar
More volume on the larger line, so why would you want to use a smaller line?
3/8 = 6/16 > 5/16
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is online now   Reply With Quote
Old 07-03-2019, 12:34 PM   #5
The Rocknrod
Too Cool For School
I'm askin the question why would I need a 3/8 vs 5/16?
1948 GMC Panel
Old 07-03-2019, 12:41 PM   #6
WorkinLonghorn
WorkinLonghorn's Avatar
Either size is fine IMO. Your 625 cfm carb can only use about one once of fuel per second. That is ~2 tablespoons per second.
'69 GMC C2500 Custom Camper, 8 1/2' bed (same as Chevy "Longhorn"), 350 ci. mild RV cam, NP 435 CR 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent.
WorkinLonghorn is online now   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
