Old 07-06-2019, 01:42 PM   #1
dave`12
dave`12's Avatar
High idle issue
I recently put a Holly Demon 625 cfm with electric choke on my 350cid engine. I've noticed that the idle is always high when I pull up to a stoplight/stop sign while driving. I burp the throttle and the idle will go down to normal. I don't have a tach, but it feels like about 1000-1100rpm.
This happens all the time, hot or cold. Every time I stop, the idle will be a little high, and I have to tap the gas to get it to go down. I have a/c, but it is off, and does not have an idle solenoid anyway.
I have the electric choke set all the way to lean, but it was doing it at the factory setting as well. I don't think I have any vacuum leaks because of the fact that it goes down when I tap the gas. The throttle return spring seems ok, maybe a little soft, but still, if it the idle goes down, could that be it?
Any help appreciated.
thanx
1967 C-10 4-speed, 350v8
dave`12 is offline   Reply With Quote
Old 07-06-2019, 02:00 PM   #2
geezer#99
geezer#99's Avatar
Re: High idle issue
Weights in the distributor could be sticky.
Or a spring popped off.
Old 07-07-2019, 12:21 PM   #3
dave`12
dave`12's Avatar
Re: High idle issue
I hadn't thought of that, good thing to check.
thanx
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
