Old 07-09-2019, 11:14 AM   #1
JQ-72
JQ-72's Avatar
Power steering not working
On a newly acquired truck that I just got running, the power steering is not working at all. No whining noise coming from the pump and it steers just like a manual. Where do I start first - pump or gear box? If it matters, it's a 1971 with 402 engine. Thanks.
72 Cheyenne Super swb. Factory 402/400,tach,posi,AM/FM, A/C. Adding cruise, 8-track
72 Cheyenne Super swb. 350/350 A/C, bucket seats
72 Custom Deluxe Highlander swb. 350/350, normal pkg. C options
72 GMC Sierra Grande lwb. 350/350, ps, pb, A/C
78 Silverado Big 10 swb.
JQ-72 is offline   Reply With Quote
Old 07-09-2019, 11:47 AM   #2
sweetk30
selective wrench turner guy
sweetk30's Avatar
Re: Power steering not working
fluid level engine off - note its level on the stick .
fire it up see if level changes .
also see if the fluid is moving around in the tank .
i would almost bet the pump died .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
sweetk30 is offline   Reply With Quote
Old 07-09-2019, 12:36 PM   #3
JQ-72
JQ-72's Avatar
It is a factory big block truck with the remote fill canister mounted to the fender. There is fluid showing inside the canister. Should I be able to see the fluid circulating with the canister being mounted that high?
Old 07-09-2019, 03:39 PM   #4
sweetk30
sweetk30's Avatar
only if there is more than 1 hose to the remote can . otherwise its just a storage tank up there .
at that point the cheaper option is drain / replace oil and put on a pump as its cheaper than a box .
make sure to raise wheels off the ground .
do NOT start engine .
turn them lock to lock as you add fluid but turn slow as to not foam the fluid with air .
once fluid level is stable fire for 10-15 sec and shut down .
redo turn and fill until stable level .
fire up and let run and top off and turn lock to lock and keep oil level up .
doing this gets the air out and not foam the fluid to bad and kill a new pump .
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
