Old 07-11-2019, 06:07 AM   #1
dxbraptor
c10 72 brake caliper casting
hi
i just bout a c10 72 fitted with disk brakes this car was parked for a long time so i am rebuilding the brakes but i couldn't identify the calipers
the rear one has casting number 4611
and the front 474177
so what is the part number as i am towards changing the caliper because they are rusted or try to rebuild it if possible.
tried to google it but I got confused .
any help appreciated .
dxbraptor is offline   Reply With Quote
Old 07-11-2019, 08:19 AM   #2
geezer#99
geezer#99's Avatar
Re: c10 72 brake caliper casting
Take some pics.
Someone might see if it’s stock or after market.
Old 07-13-2019, 12:27 PM   #3
dxbraptor
Enclosed the images
Old 07-14-2019, 08:13 PM   #4
AcampoDave
AcampoDave's Avatar
It has calipers on the rear?
AcampoDave is offline   Reply With Quote
Old 07-17-2019, 08:30 AM   #5
dxbraptor
Yes
Old 07-17-2019, 09:31 AM   #6
AcampoDave
AcampoDave's Avatar
1972's originally had disc on the front and drum brakes on the rear. I would bet somebody has replaced the whole rear end with something from a different GM vehicle. It's likely a good bet to assume the front could just be obtianed from an auto parts store using the factory info, but as for the rear you would need to know the original application of the rear axle. Perhaps if you post a pic of the rear end somebody here may be able identify it and give you some idea as to what kind of cars used it.
Old 07-17-2019, 11:06 AM   #7
The Rocknrod
Too Cool For School
The Rocknrod's Avatar
x-ref for Casting 5474177 Disc Brake Caliper:
BENDIX - R55060
BENDIX - R55383
AUTOSPECIALTY - 41-82045
CENTRIC - 141.62045
CENTRIC - 141.66001
NAPA - 42-2001
Master Chief, US Navy, Retired - He ain't no drag Papa's got a brand new bag
1964 C10 Step-side Short Bed - In Progress
2009 2500HD Duramax LTZ
1948 GMC Panel
1956 Big Window Stepside
1953 5 Window Chevy Stepside
New Seat Foam for Bench Seats?
Old 07-17-2019, 12:15 PM   #8
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Still got a truck 12 bolt in it?
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
GASoline71 is offline   Reply With Quote
Old 07-17-2019, 01:04 PM   #9
dxbraptor
If u have the gm part will be great becouse the parts guys here are so lazy.
Old 07-17-2019, 10:21 PM   #10
kwmech
If the inside of the bore is clean along with the piston you can rebuild them yourself. Looks like the standard GM 1/2 caliper (same as the front) from 1971 up to 1991
kwmech is online now   Reply With Quote
Old 07-18-2019, 03:11 PM   #11
dxbraptor
The deferential image
Old 07-18-2019, 10:57 PM   #12
Captainfab
60-66 Nut
That's a truck 12 bolt. Likely original to the truck. A disc brake conversion has obviously been added. What is the center to center measurement of the bolt holes on the rear calipers.They should be either 5.5" or 7.0". Also what is the thickness of the rear rotors?
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
