03-11-2017, 10:52 PM | #51 |
Re: 1963 VW Convertible Build
Covered my first seat ever yesterday... sorta late for that being that I'm an upholsterer's son. Still needs to be steamed to get the wrinkles out from it being boxed.
Also finished the carpet and all but one door panel.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
03-12-2017, 08:53 AM | #52 |
Looking great ,how does the bug body go back on the frame ,bolted or welded ?
03-12-2017, 09:02 AM | #53 |
Thanks flashed! There are around 30-40 bolts around the perimeter of the frame that hold them together.
03-12-2017, 09:09 AM | #54 |
Im learning from you just watching on this as I never had a Bug .There is a place one county north of me ,my hometown ,where all they do is restore old VW"s that I keep wanting to stop in .Love your work ,hope you are always willing to share it with us .
03-19-2017, 01:07 AM | #55 |
I picked up the frame, suspension parts, and engine tin from the powdercoater on Friday. I was in a friend's wedding today so I wasn't able to get much done.
I did have enough time to bend the brake lines. I bought a stainless line set but it was all straight lengths so I made patterns with wire then bent the lines to match. Forgot to take pics of the rear lines.
03-19-2017, 08:58 AM | #56 |
All looks very nice .
03-20-2017, 09:11 AM | #57 |
Ridiculously awesome as always. Been following along on facespace, and just saw this thread
I also like the first set of wheels, but that new set is sooooooo much cooler. Hope you can find a pair for the back!
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
03-20-2017, 12:32 PM | #58 | |
I narrowed and re-dimpled the torsion leaves yesterday afternoon so I could start reassembling the front suspension. Got it all back together except the steering box and tie rods. Finished the rear brake lines Saturday night.
03-21-2017, 10:04 PM | #59 |
Got the tires mounted and balanced yesterday and put the steering components together today.
Also assembled and installed the headlight assemblies. I used Cibie e-code headlights, 90/100 watt Narva H4 bulbs, and the wiring is 12g with ceramic sockets that will be hooked up to a relay harness.
03-22-2017, 11:21 AM | #60 |
Damn, you don't mess around!!!
03-22-2017, 11:28 AM | #61 |
Love the detail, lenses look great! What size tires will you be running, I like that the fronts look to be nice and wide, not a 135 or 145.
03-22-2017, 11:52 AM | #62 |
Trying to have it finished enough to drive it to the first Rod Run in Pigeon Forge... 2.5 weeks left!
Thanks! I ran 145's on my '64 and hated them, no grip at all. These are 195/50's front and 196/60 rear.
03-22-2017, 12:36 PM | #63 |
Just in time for convertible season!
Robert |
03-26-2017, 09:11 PM | #64 |
You make it look easy.
It took me 8 months and I didn't even paint it lol me NICE.
70 c10 2wd crashed Suburban 67 c10 2wd sb truck 67 c10 4wd lb truck |
03-29-2017, 09:50 PM | #65 |
Got a little more done this week. Installed the decklid along with a NOS license plate frame from the local VW dealership that was around in the '60s-90's.
Test fit the floor mats so I could trim around the shifter and heater openings. Stripped and detailed the pedal assembly. Detailed the rear adapters, axle tubes, horn ring, bought a radio, pulled a 912 wheel out of storage to use as the spare tire, and bought a set of German ceramic/brass fuses.
03-30-2017, 08:33 PM | #66 |
Nice work. Looks amazing
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
03-30-2017, 09:20 PM | #67 |
Wow! Love your work!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
04-08-2017, 08:03 PM | #68 |
Thanks dudes!
04-08-2017, 08:33 PM | #69 |
Started building the engine. All of the clearances checked out during mock up except the deck height, so the pistons are at the machine shop for a quick hair cut.
I set up the distributor drive end play while the block was still split. Bottom end buttoned up, checking the deck height. Picked up the transaxle on Thursday, scrubbed it down and painted it, then cut out the end of a box and used a hair dryer to dry the paint faster. Rear brakes assembled. With the trans and brakes done I had the frame 99% finished so I pushed it out for a few pics.
04-08-2017, 09:59 PM | #70 |
The bug looks great...I love your level of detail..
I have always loved the look of those classic Porsche wheels. Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
04-09-2017, 01:23 PM | #71 |
Looks like my other post didn't go through...
I hoisted the body up and dropped it on the frame yesterday.
04-09-2017, 01:23 PM | #72 |
Appreciate it!
04-09-2017, 05:12 PM | #73 |
That is slick!
04-09-2017, 06:53 PM | #74 |
Looks great ,cant believe how fast you are getting it done .
04-11-2017, 04:59 PM | #75 |
How much the Fuchs go for this days ? I still have 4.5x15s & 6x15s just asking. Cool ride.
