05-28-2017, 07:35 PM | #1 |
Spindle and flip kit
I did some searching around on the forum but did not find what I'm looking for; has anyone done 2.5 drop spindles and flip kit with no changes to front coils? Was it level or too low in the rear? Thanks
05-28-2017, 08:22 PM | #2 |
Re: Spindle and flip kit
I believe most 2WD trucks (stock) sit about 2" higher in the rear. My estimate, and I aint too bright, it'll sit down -2.5" in the front and you'll loose -6" in the back. So, that's what...the back end sitting 1.5" lower than the front?????? MMMMMMM?
Mike
Instagram @HomeBuiltC10s Dads 79 GMC Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=642929 1978 Silverado Build http://67-72chevytrucks.com/vboard/s...d.php?t=756016 |
05-28-2017, 09:03 PM | #3 |
Ok. Thanks. Guess its time to cut a coil.
05-28-2017, 09:04 PM | #4 |
That's just one opinion. Others will chime in.....
05-28-2017, 10:37 PM | #5 |
Diggin The SquareLife
2/4 drop will make it sit level also a 3/5 4/6 and 5/7 so yea the rear will sit lower with a flip kit an jus springs in the front....also don't cut your stock springs....buy some big block springs an cut those
05-29-2017, 07:05 AM | #6 |
Watch out for your cornhole !
Cut your stock springs. You already own them free and clear. Maybe, if you have a complaint about the ride, consider buying the big block springs and cutting them. I'm betting you won't have any complaint about the ride that cut stockers give you though.
05-29-2017, 11:12 AM | #7 |
Thanks for all of the replies. I'm going to flip the rear today and see how it looks. 2.5 cpp drop spinles up front, i think I forgot that part. Also rear tires are 275/60r15. 255/60r15 up front.
05-30-2017, 09:44 AM | #8 |
I'm curious what the average height loss would be by snipping stock small block coil springs. I am finishing up my rear suspension swap and now have to get the front to match.
05-30-2017, 10:33 AM | #9 |
What about shocks? at what point would lowering shocks need to be purchases?
05-30-2017, 10:38 AM | #10 |
Typically one coil is 2"
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
05-30-2017, 10:40 AM | #11 |
Anything beyond 2" of spring drop will prob need adjustments to the shock travel (different shocks or changing the mounting points for corrected length). This is a subjective issue. One guy might notice while another doesn't (or doesn't care).
05-30-2017, 07:30 PM | #12 | |
driving is in my blood
I have 3" spindles and 2" springs on my 78 with oem shocks, rides fine. My 79 lowered the same needed drop shocks. Guess it was the difference in spring manufacturers.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
