Old 12-28-2023, 10:39 PM   #1
cag
1962 gmc c20 rear gear ratio???
v6 with speed, dana 60, any ideas on rear gear? no tag....
cag is offline   Reply With Quote
Old 12-29-2023, 12:15 AM   #2
Getter-Done
Getter-Done's Avatar
Re: 1962 gmc c20 rear gear ratio???
84 Chevy K-20
Old 12-29-2023, 12:30 AM   #3
cwcarpenter98
cwcarpenter98's Avatar
Put one piece of tape on the inside of one tire. Line up with an easily recognizable spot (or another piece of tape on the ground or inner fender. Put one piece of tape on your pinion yoke. Again, line up with an easily recognizable spot. I did mine with the pinion yoke mark pointed straight down to the ground.
Open Diff: Make two full rotations of the tire, count how many revolutions you have on the pinion yoke. Only lift one tire off the ground to do this.
Posi Diff: Make one full rotation of the tire, count how many revolutions you have on the pinion yoke. Need both tires off the ground.
Christian Carpenter
1963 C10 - Frankentruck 283, 3 speed with overdrive
Overdrive wiring here
1981 C10 - Penny 305, th350
1995 Dodge Dakota Sport
Old 12-30-2023, 10:09 PM   #4
factorystock
factorystock's Avatar
4.10 would have been standard on a GMC V6. 4.57 would have been standard on a Chevy.
factorystock is offline   Reply With Quote
Old 01-07-2024, 05:18 PM   #5
cag
thanks all yall!
Old 01-07-2024, 07:35 PM   #6
Getter-Done
So,?
Did you find out what Ratio you have?
And how did you go about it?
Inquiring minds want to know.
84 Chevy K-20
Old 01-09-2024, 12:35 PM   #7
cag
Originally Posted by Getter-Done View Post
So,?
maybe in the spring,,,,,,
