Old 08-29-2018, 08:09 AM   #26
ncpetersc
ncpetersc's Avatar
Re: Fuel Gauge not working????
I don't think it's typically a wire. The tank gets grounded through the mounting hardware and brackets clamping it to the cab. You do want to make sure that there is nice clean metal somewhere for the tank to ground to the cab.
1972 C-10 [Boppa's Truck]
ncpetersc is offline   Reply With Quote
Old 08-29-2018, 12:42 PM   #27
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Absolutely!
Just do the ohms check from tank to cab and from the sending unit terminal to the tank. You may have fried the variable resistor in the sender . I ordered mine from Parts Geek.com and it is amazing. There is a difference between them. The stock units for six cylinders are 5/16ths and the V-8s are 3/8ths inch diameter tubes.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 10-18-2021, 11:56 AM   #28
jondancer
Anyone have any working fuel gauges that they would sell ?
jondancer is offline   Reply With Quote
Old 10-18-2021, 05:10 PM   #29
BigBird05
I have one out of a 72 C-10. If you want it I will bench test it to verify it is good. $30.00 + shipping. PS it is from a non gauge truck.
BigBird05 is offline   Reply With Quote
Old 10-18-2021, 06:31 PM   #30
jondancer
What’s a non gauge truck
Old 10-18-2021, 09:20 PM   #31
BigBird05
Instead of a temp gauge and a amp meter it has idiot lights. The fuel gauge and speedometer look the same in a instrument cluster.
