Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 GMT400 Chevy & GMC Pickups Message Board > projects and builds 88-98
Old 03-29-2018, 01:02 AM   #101
fredscarryall
fredscarryall's Avatar
Re: Fastfreddys 454ss
Trial fit the ram air cowl hood today. Now it’s time to cut a hole in the front scoop and make the ram air functional
fredscarryall is offline   Reply With Quote
Old 03-31-2018, 02:09 AM   #102
fredscarryall
Ram air hood is now functional
Old 03-31-2018, 02:36 AM   #103
fredscarryall
I used a moroso 97070 air pan foam,k&n 03351 base plate,air 801-452 air filter,k&n 14”x4 air filter(filters stacked on top of each other),and a k&n 66-1100 x-stream 11” top filter
Old 03-31-2018, 02:48 AM   #104
fredscarryall
Also used a 16” deep dish pizza pan, had to extend the center carb stud with spectre 42133 air cleaner stud kit, aluminum gutter screen,a piece of 1/8 3’x3’ sheet of aluminum and then anchored it down with #10 self tappers. Its solid and doesn’t flex at all
Old 04-03-2018, 12:09 AM   #105
fredscarryall
Finally got a decent day to take some picture with all the recent upgrades
Old 04-03-2018, 01:32 AM   #106
fredscarryall
Next is the rear roll pan with wind diffuser (I will see how close I can get to my rendering)and interior,but I’m changing the carpet and center console to black. I got the carpet from classic industries but I think I will lay some dynomat down first.Then using some bucket seats from a 2015 dodge caravan that are black with a red stitch off craiglist for $200 ( I just have to figure out what wires goes to the side air bags and not hook them up). For all the purist. I am still saving everthing. So no 454ss’s were harmed in these mods.
Old 04-05-2018, 12:07 AM   #107
fredscarryall
Mocked up the fiberglass roll pan I got off amazon today. Fits pretty good for fiberglass.Now I have to take it off to install the diffuser fins and paint it.
Old 04-16-2018, 12:42 AM   #108
fredscarryall
Painted the rear roll pan. I though I would give a preval sprayer a tray again.I sprayed a single stage urethane. Works really well. Not bad for $12 including a rustoleum hand sprayer from Home Depot (I went through 1 sprayer with a jar and 1 refill) I used this same sprayer when I painted a hood a few years ago. Just make sure you use a high end primer no rustoleum or dulicolor.You don’t need any special filters and you throw the air sprayer cartridge away after your done. Great alternative to someone who doesn’t have a compressor.Gives you a little bit of orange peel over a real spray gun. But I was planning on cutting and buffing it anyway. Next I will double stick the air fins.
Old 04-16-2018, 12:54 AM   #109
fredscarryall
Final results on the the roll pan sprayer with the preval sprayer. This week is the hood. I going to spray the hood with a $27 harbor freight gun with 20% off coupon.I did a firewall a few years ago with this same gun and it turn out awesome.
Old 04-21-2018, 01:13 AM   #110
fredscarryall
Taught my 17 year old neighbor how to paint a hood today. Turn out perfect. Had a little freight damage that I had to take care of first. Next week I’m going to tint the windows. Then start on the interior. Going to install the black carpet, dynomat the floor, finish wiring the sound system, replace the seats and dye the door panels black that I got off ebay. There goes another tote to fill with the factory stock parts. Should take about a week on the interior. Then comes the engine performance mods.
Old 04-21-2018, 09:57 AM   #111
arrg
What paint are you using?
1988 Chevrolet C1500 RCSB
arrg is offline   Reply With Quote
Old 04-21-2018, 02:57 PM   #112
jjzepplin
jjzepplin's Avatar
That's nice!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 04-21-2018, 10:53 PM   #113
fredscarryall
The paint is a limco single stage urethane
Old 04-21-2018, 11:51 PM   #114
mingoman
Coming along nicely Fred!
76/77/78 Cheyenne
1997 K3500 454 soon to be 496
mingoman is offline   Reply With Quote
Old 04-22-2018, 02:34 PM   #115
SCOTI
SCOTI's Avatar
I've been looking @ this style of hood to replace my damaged one. Steel hood? Manufacturer?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-23-2018, 02:06 AM   #116
fredscarryall
I bought the hood off summit racing. It was $319 with an extra $99 for freight. Best priced hood anywhere and they fit really well. It’s all steel. Does not come with a spring or release. Make sure you save those before you hall your damaged hood off. What they don’t show or tell your is this hood comes with a plastic ram air intake insert. But if you want to cut the intake out, the best tool I found is an air reciprocating saw. I added a pic of the back of hood
Old 04-23-2018, 02:25 AM   #117
fredscarryall
Here’s another pic that they don’t show you. The back of the ram air cowl hood
Old 04-23-2018, 11:57 PM   #118
fredscarryall
Pics of the finished ram air hood
Old 04-24-2018, 12:00 AM   #119
fredscarryall
Finished roll pan air diffuser
Old 04-24-2018, 09:34 PM   #120
hutcholdschool
Beautiful work. Your truck looks great.
hutcholdschool is offline   Reply With Quote
Old 04-28-2018, 07:55 AM   #121
fredscarryall
Would not let me remove this post
Old 05-25-2018, 02:24 AM   #122
fredscarryall
This might bore some of you. But I desided to send out my tbi to tbiparts for a rebuild off ebay. I had the throttle blade base plate bored to 54mm, thinner blades, and removed the adjustable internal regulator. Since I have no way to adjust the fuel pressure, since I removed the internal tbi regulator. I added an external fuel regulator with a gauge. I really did want to spend $150 on a aeromtive 13301, $150 on earl an fittings and a $30 gauge. I decided to buy a universal adjustable fuel regulator off amazon for $55. There were a lot of good reviews on this regulator. But the only think is you have to buy better o,-ring for the 3/8 fitting into the regulator and the fuel lines included in the kit are to short and are garbage. So you need to buy about 5 feet of braided fuel line.The only two fitting I had to buy was for the 5/16 metal fuel line to 6an and a fitting from the return on the tbi to the return. If the adjustable fuel regulator sucks. I’ll just Buy an aeromotive regulator and still be money ahead.
Old 05-25-2018, 02:37 AM   #123
fredscarryall
I had a hard time incorporating the fuel lines and return line to a external regulator while using the factory tbi.I ran tons of dead head fuel regulator in cars and trucks with carbs. But never for a fuel injection system with a return line. Im sure a lot of others may be wondering how to run the fuel and return line. Got it figured out thanks to nastyz.Here is a diagram on how I ran it to save money. I mounted it up front so it’s easy to adjust. I decided to keep the factory fuel inlet line that comes from the fuel pump to the tbi. I also bought a mechanical fuel gauge instead of using the liquid filled gauge that comes in the kit. Because when the liquid in the gauge gets hot from the engine heat. The gauge can be off by 20 psi. Here is a diagram I drew out and of few pics of how and where I mounted it. I won’t get my tbi back till next week. The last picture is a before pic for reference.
Old 05-25-2018, 03:28 AM   #124
fredscarryall
Also found aluminum radiator for our 88 to 98 trucks. I have used these radiators on 3 builds with 180 degree thermostat and the temperature never got above 185 on 90 degree days cruising at 5 mph. Made in the USA. Champion radiator makes two sizes that have transmission and oil cooler lines ( but you can be plug them off if you have a manual trans or don’t have a built in oil cooler),includes heater core line out. Also depending on which one you pick.They make standard and extended fill neck.The cc1520 with a 34” wide core and a 40 5/8 overall and a cc622 with a 28” core and 20 1/4 overall.You can save a lot of my money with free shipping buying the radiators from ebay for $200. Way better then griffins $750 just for the radiator. Champion says they price match but I didn’t ask.If you buy the cc1520, champion does not make a dual 16” fan shroud so you have to buy the shroud off ebay for $100. If you use the cc622 with the 28” core you have to buy the 14” dual fan shroud from champion radiator ( but will need minor mods to fit) Make sure you buy a temp sensor relay kit, unless you want to run a toggle. But the dual fan kit 170 off/ 185 on needs to be bought from summit racing, jegs, ebay or amazon. I’m saving the old radiator, shroud and fan. So it could be put back to stock
Old 05-25-2018, 03:31 AM   #125
fredscarryall
Here is a pic of the fan shroud for the cc1520
