Old 06-03-2008, 09:56 AM   #1
jchav62
1962 C-10
jchav62's Avatar
Angry Spare tire carrier problem.
I have an 04 Silverado z71. This morning it had a flat and I went to change it but the spare tire wouldn't drop... Has anyone had this problem before??
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 06-03-2008, 10:46 AM   #2
truckdude239
truckdude239's Avatar
Re: Spare tire carrier problem.
u might have to pull on the tire and while lowing it try t jerk it sounds like the cable is froze once you get ti down lube everything with a good white limitum Greece
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 06-03-2008, 10:50 AM   #3
jchav62
1962 C-10
jchav62's Avatar
Figured it out... Thanks!
Joseph Chavez
Old 06-03-2008, 10:50 AM   #4
1BAD64
1BAD64's Avatar
make sure it doesnt need the lock key on the end of the crank rod.it should be in the glove box (if it needs it ) looks like a locking lug nut key but smaller.just a thought
1BAD64 is offline   Reply With Quote
Old 06-03-2008, 08:43 PM   #5
gmcracing92
Drillin oil on American Soil!
gmcracing92's Avatar
i had the same prob, would only move an inch up or down, so i ended up taking the torch out and cutting it down. pos
Travis
70 Chevy c20 2wd
75 Chevy k10 4x4 parts truck
92 GMC Sierra c1500 2wd DD
99 Chevy Reg Cab Sht Box 1500 2wd
05 GMC Sierra Denali white
gmcracing92 is offline   Reply With Quote
Old 06-04-2008, 09:43 PM   #6
finch
finch's Avatar
pried on mine with 2 pieces of pipe, nothin. just left it for a later date. going to get a matching spare and mount it on the roof.
finch is offline   Reply With Quote
Old 06-07-2008, 11:48 AM   #7
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
Just an FYI some of these had a problem with the spare being sucked up too tight and bowing the plastic tube you have to stick the rod through to drop the spare. There is an updated extension that is flexable to get it down if all else fails.
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
