Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Suspension > Suspension Marketplace
Old 10-14-2013, 07:44 PM   #1
Pro Performance
Pro Performance's Avatar
New! 14" Baer Big Brake Kit - $999
New - 14" Big Brake Kit - $999
We have been working with Baer on a new brake kit for the C10's, which will be exclusively only through Pro Performance. This new brake kit will work with any factory disc brake spindle or factory style disc brake drop spindle, such as McGaughys, Early Classic, BellTech, etc. We feel this is an important feature of the brake system, because it doesn't require you to change spindles, and can use what you already have. You will receive a template and instructions on modifying your spindle, which requires cutting of the caliper "ears" and drilling and tapping for the caliper mounting bracket.
Note: Photos shown are preliminary mock up photos, available in 5 & 6 lug.
Key Features:
1) No need to buy new spindles, just modify current spindles
2) Uses new calipers, not rebuilt
3) Precise machined hub
4) Laser cut mounting bracket
5) Fits in most 18" wheels and larger
6) Will work with most aftermarket wheels, since caliper offset is kept to a minimum.
Kit Includes:
- C5 Caliper - New (Not Rebuilt)
- 14" 1-Pc. Rotor, Drilled / Slotted with Directional Vanes (1.1" Thick)
- Machined Aluminum Hub - 5x5 Bolt Pattern
- Caliper Mounting Bracket
- All Necessary Hardware
- Brake Pads
AZProPerformance.com | 480-420-8175
Contact Us About Our Monthly Specials
Wheels / Tires / Suspension / Brakes / Air Suspension Components
Choppin' Block - AccuAir - McGaughys - Raceline Wheels - Hot Rods by Boyd - American Racing - Schott - Boze - Wilwood - Baer & More!
Pro Performance is offline   Reply With Quote
Old 10-15-2013, 10:03 AM   #2
MattPSU
MattPSU's Avatar
Re: New! 14" Baer Big Brake Kit - $999
Very nice. Great price point too. Add this to my ever growing list...
Matt Criswell - Lyman, SC
1972 Chevy Cheyenne SWB - Build: Porterbuilt State 1 Front & Rear, Bolt in Notch, McGaughys 2.5 Drop Spindles, Boyd Welding Fuel Tank
UPSTATE SC GM TRUCK CLUB: FACEBOOK WEBSITE
MattPSU is offline   Reply With Quote
Old 10-15-2013, 12:21 PM   #3
sduckworth13
sduckworth13's Avatar
Travis, will the caliper be powercoated and say Baer on it? Can you also use the CPP Modular 2" inch drop spindle with this setup?
Thanks,
Scott
Scott
sduckworth13 is offline   Reply With Quote
Old 10-15-2013, 12:32 PM   #4
Pro Performance
Thanks!
Thanks,
Scott
It won't be available powder coated or have the Baer name on it. It will be from Baer, so you know it will be a nice quality kit. This was to keep cost down. This kit is intended for the stock disc brake spindle, or a stock style drop spindle such as McGaughys, BellTech, ECE, etc.
If looking for a brake kit for the CPP spindle, which most big brake kits require, I would take a look at our T4 system we offer.
http://www.azproperformance.com/Baer...C10-5-Lug.html
Old 10-15-2013, 12:42 PM   #5
sduckworth13
Nice thanks for the info Travis.
Scott
Old 11-22-2013, 01:51 PM   #6
Pro Performance
Got this new kit uploaded to the site:
http://www.azproperformance.com/Baer...60-87-C10.html
Old 11-22-2013, 02:13 PM   #7
sduckworth13
I'm still saving up, but these brakes are on my list. Your newly updated website looks great Travis.
Scott
Old 11-22-2013, 03:14 PM   #8
Pro Performance
Thanks Scott, we are always adding more and more to the site. There is so much we offer, just takes a lot of time to get it uploaded on the site properly.
Old 01-19-2014, 05:36 PM   #9
leemer4
leemer4's Avatar
Just painted my big brake kit calipers. I hope these live up to the rep.
leemer4 is offline   Reply With Quote
Old 01-20-2014, 03:53 PM   #10
Pro Performance
Looks great and thanks for sharing! You will definitely notice a difference in braking performance with this kit. If you have any more pictures of them installed, please send to travis@azproperformance.com, and would like to add them to the site.
Old 01-26-2014, 06:49 PM   #11
leemer4
leemer4's Avatar
The instructions seem to be lacking In a little detail. It is not clear about the shimming. What part of the caliper saddle should be measured to center it on the rotor? Any advise will help.
Old 01-27-2014, 03:20 PM   #12
Pro Performance
Center the rotor between these 2 points on the caliper saddle bracket.
Old 02-01-2014, 07:32 PM   #13
leemer4
leemer4's Avatar
I think I worked it out, but if you center it on the dimension you show, the rotor will drag. Yi used the narrower dimension of the frame.
Old 02-02-2014, 02:33 PM   #14
leemer4
leemer4's Avatar
The flex Line to hardline fitting is the wrong size for 1972 C10.
Stock hardline male flared fitting at the caliper is 7/16" inverted flare male.
The fitting provided is either metric (10mm) or 3/8" inverted flared female.
Can you advise on obtaining the correct adapter ( your AN size male to 7/16" inverted flared female?
Old 02-03-2014, 01:32 PM   #15
Pro Performance
They ship with the standard 3/8" IF Female fittings, but I can get the 7/16" IF Female shipped to you. I will get them on their way.
Thanks,
Travis
Old 02-03-2014, 06:08 PM   #16
leemer4
leemer4's Avatar
Thanks! do you have my contact information - I can send a private note if needed.
Old 02-03-2014, 06:39 PM   #17
Pro Performance
No problem.... I had the same address you PM'd me. Thanks! Baer will get them in tomorrow, so should ship in a few days.
Old 02-03-2014, 10:11 PM   #18
leemer4
leemer4's Avatar
Awesome service thank you very much!
Old 02-27-2014, 01:23 AM   #19
leemer4
leemer4's Avatar
Getting closer.
Old 02-27-2014, 01:08 PM   #20
aggie91
I'm just glad to be here!
aggie91's Avatar
Travis, Can I get just the hub from this kit?
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 02-27-2014, 04:14 PM   #21
Pro Performance
Originally Posted by leemer4 View Post
Getting closer.
Looks great and will have to add these images to my site, if you don;t mind.
Yes, just the hubs are available separately.
Old 02-27-2014, 04:16 PM   #22
Pro Performance
The rear kit will be ready to ship early next week. We designed the rear kit so that no machining to the axle or rotor is required, since we actually use a truck rotor.
Old 03-09-2014, 03:08 PM   #23
fishingjred73
fishingjred73's Avatar
Any more info on the rear kit?
James
'68 Stepside (ground up in progress)
My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html
'81 SWB "Pap paw" (Driver)
The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html
Member of
www.louisianaclassictruckclub.com
https://www.facebook.com/groups/296290610747732/
fishingjred73 is offline   Reply With Quote
Old 03-11-2014, 12:05 AM   #24
Pro Performance
The rear kit will use a 14" cross drilled, slotted and zinced rotor. This is a true truck rotor, so no machining to the axles or rotor is need to fit the truck. For a caliper, it uses the Mustang rear with integrated parking brake. We went with this caliper because it accepted the truck rotor thickness, had an integrated park brake, and worked with the larger 14" size.
Brackets have just arrived, so kits are ready to ship and have a few going out this week.
When you buy the front and rear together, it is package priced @ $1,695. If you want to add DOT stainless lines, it is an extra $185.
- Travis
Old 03-11-2014, 12:39 AM   #25
mongoose
mongoose's Avatar
is that for full lines or just braided pieces front and back?
and what spindles are these for? the 1" or 1.25"?
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
