07-20-2017, 09:54 AM | #1 |
Closing the cab fuel fill hole
Does anybody make a form fitting plate that can be tacked in?
Right now I have a tennis ball stuffed into the grommet. It would not be good if someone were to pour gas into the cab. |
07-20-2017, 10:04 AM | #2 |
Moderator
Re: Closing the cab fuel fill hole
Pour gas into the cab...
I'm just trying to imagine the situation. "Yes police?, It was a wondering gang of gas pourers"..."they should be easy to spot"
07-20-2017, 10:11 AM | #3 |
Rockinrod~ "Free gas drop off, please insert through this whole in my cab" Wouldnt that be nice? Anyways, all you can do is hack 'n tack a piece of metal yourself. Grind and fill with bondo. I like the aluminum based body fillers they make now to ward off cracking and moisture seepage but that stuff is difficult to sand after it hardens. Its been about 5 years since I did my novice job with a small wire feed welder and it still is doin fine. I always spray a little rubberized undercoating behind my welds if I can because my work is ugly.
07-20-2017, 10:32 AM | #4 |
[QUOTE=vince1;7995526]Does anybody make a form fitting plate that can be tacked in?
Check out Item # 152630883314 on E Bay it's $14.95 with $ 8.00 shipping |
07-20-2017, 11:04 AM | #5 |
If you have an old door, you can cut your own. I was lucky to have an old rusted door back in the day when I did mine.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
07-20-2017, 11:31 AM | #6 |
Never Ending Projects
[quote=Indian113;7995563]I used one of this seller's fill panels for my '68 truck and it fit great.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
07-20-2017, 01:12 PM | #7 |
Thanks Chevy Mike, It's good to get a 1st hand Review! I will need one for my 64 this winter.
07-20-2017, 05:01 PM | #8 |
07-20-2017, 06:52 PM | #9 |
There is very little crown to this area. A circular piece of sheet metal with just a little hammering to stretch metal ever so slightly would do the trick. Body filler would take of the rest if you're not exact.
07-21-2017, 12:25 AM | #10 |
LMC now sells one, in their latest catalog, page 77 with exterior accessories.
why it's not with the cab sheet metal....or gas tank stuff...??? The order of their catalog always seems strange to me. anyway, it's $10
292 + TKO500 Last edited by Heater63; 07-21-2017 at 01:46 AM. |
07-21-2017, 12:43 AM | #11 |
Or just put a locking gas cap on there and throw the keys away.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
07-21-2017, 02:56 PM | #12 |
We still have plenty of full serve gas stations in Canada, where they pump the gas for you
1961 GMC half ton, short step, Canadian model. Just starting work on it. |
07-21-2017, 04:13 PM | #13 |
A friend of mine let someone barrow his truck and they pumped gas into his cab. I JB welded a stock looking painted cap on to my filler neck until I had it shaved.
07-21-2017, 05:37 PM | #14 |
I pretty much did the same. Kept the filler neck with a regular chrome cap. The rubber gasket holds it pretty secure along with a hose clamp around the filler neck on the backside just in case. Something to block any attempts of filling would be a good idea.
07-21-2017, 06:33 PM | #15 |
Made me think of the old Andy Griffith show when Barney was in the armored truck and Gomer was pumping gas in thru the gun port..
