Old 05-29-2019, 10:35 AM   #1
GMCNUT
GMCNUT's Avatar
Ignition woes - switch needed?
I don't know why, but when its cold or started for the first time, my 72 blazer ignition has started hanging when I hit the key and the starter will turn over and over and over a thousand times unless the motor starts or I disco the battery. When hot, its started deciding not to crank at all - flip the switch and nothing happens like its totally disconnected from power. After it cools down, seems to start fine. Assumed at first this was a starter solenoid issue, so I replaced that with a brand new one only to see it act the very same. So turned my attention to the ignition switch and replaced it with a same switch spare I had laying around from a junk yard truck, and it is still doing the same thing. So I assume the junkyard ignition switch was as bad as the one I swapped it out with? New solenoid? Can't be the starter itself I would't think because it waits for the ignition to be turned on to make the solenoid jump out - the solenoid would work regardless of the starter working and thats not occurring so it has to be the switch itself - right?
So, assuming all of you agree the switch must be as bad as the one I removed, Ebay shows about 10 different ignition switches and each seller claims their switch is correct for 67-72 - part numbers I see are:
1116695, 1116704, 1116688, 1116711 and on and on. Does anyone really know what GM part # the ignition switch is supposed to be for a 72 Blazer w/ normal 350 V8 / Automatic / CST / etc?
My Projects and Toys - All 100% Stock
1972 CST "Highlander" Blazer - #'s matching 350 auto, PS, PB, A/C, Tilt, Tach, AM/FM & Positraction + Hickey Tire carrier and Sidewinder winch
1966 Chevy SWB Fleetside BBW Custom Cab, #'s matching 327 V8 & Powerglide, factory PS, PB & A/C, Tinted Glass, sway bar
1963 GMC SWB Fleetside BBW Custom Cab, #'s matching 305V6 & 3 spd - Factory solid Black 53K orig miles "barn find"
1961 Chevy SWB Fleetside BBW Custom Cab #'s matching 283 V8 & Powerglide w/ uber-rare Cool-Pack A/C, factory PB, Clock, Tach
1960 GMC SWB Fleetside BBW Custom Cab #'s matching 305A V6 & Hydramatic, factory PB, Clock, Tach, Compass, Hood Jet
1959 Chevy SWB Fleetside BBW Custom Cab w/ rare stainless bed trim, #'s matching 283 V8 & Hydramatic, Deluxe Heat, radio
1958 Chevy Cameo #'s matching 283 V8 & Hydramatic, radio, window washers, Factory PS & PB
1958 GMC BBW SWB Fleetside Custom Cab, #'s matching 336 V8 Hydramatic, Factory PS, PB, Clock, RSD, Deluxe Heat & Hood Jet
1957 GMC Suburban Pickup (GMC's Cameo) #'s matching 347 V8 Hydramatic, uber-rare vacuum ashtray, Factory PS, PB, Clock, RSD, Hood Jet
GMCNUT is offline   Reply With Quote
Old 05-29-2019, 11:51 AM   #2
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Ignition woes - switch needed?
This looks like the real deal here: http://67-72chevytrucks.com/vboard/s...d.php?t=787220
Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, AASmedic, SoCoC10, Lumaestas, carbuff382
Old 05-29-2019, 02:19 PM   #3
A1971Blazer
A1971Blazer's Avatar
be sure to check the connector that plugs into the switch...it can short in there and cause the starter to run on like you are describing..the purple wire is what energizes the solenoid...check it for a short as well....could be shorting intermittently in that circuit...
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Copyright ©2000 - 2019, vBulletin Solutions Inc.
