Old 05-05-2015, 10:07 PM   #26
iceship
Re: How I got Hydroboost for under $80 (including lines)
Interesting"...
iceship is offline   Reply With Quote
Old 11-09-2015, 01:47 PM   #27
kehstr
kehstr's Avatar
when i did my hydro-boost, all i had to do was lengthen the rod using part of the original vacumm booster brake rod, and welded it on, and then it worked the exact same as your setup
kehstr is offline   Reply With Quote
Old 11-13-2015, 10:39 PM   #28
72blazer_mud_bogger
72blazer_mud_bogger's Avatar
What is the length of the new push rod after u welded part of the old push rod to the hydro boost rod
72blazer_mud_bogger is offline   Reply With Quote
Old 11-16-2015, 12:42 PM   #29
kehstr
kehstr's Avatar
the length will very, depending on the hydro-boost kit you use, but the pictures below will show you the amount i had to lengthen mine to make it work for me. there are also pictures of the mounting plate and what i had to do to make it work
Old 08-24-2016, 05:05 PM   #30
Beach Burb
I know this thread actually started a long time ago but this is great information. I love finding Pick 'N Pull solutions that are top quality. I pulled my entire serpentine system out of an old pickup and saved hundreds of $$ vs new GM stuff. I just sent off my vacuum power booster back to mfg. for repair/replacement, it only had around 500 miles on it. My next built will have hydroboost!
1971 Chev Suburban
1951 Chev 3100 Pickup
1953 Harley 165 ST
Beach Burb is offline   Reply With Quote
Old 09-10-2016, 06:41 PM   #31
Dutch Yellow Sub
I'm doing the conversion right now.... pulled my Hydro out of a '90ies G20 Van....
I also have to make the push-rod a bit longer....
thanks for starting this thread, very helpful!
Dutch Yellow Sub is offline   Reply With Quote
Old 01-13-2018, 07:57 PM   #32
Billyburban
Originally Posted by OneOffStroker View Post
And some finished shots:
Sexy, eh?
So question for u I just spent the day trying to complete this project but didnít happen cause the with the inner finder wouldnít fit even after I cut my inner fender to fit did you get yours to fit with inner fender ?
Billyburban is offline   Reply With Quote
Old 01-13-2018, 08:21 PM   #33
racecougar
racecougar's Avatar
What specifically is interfering?
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 01-13-2018, 10:33 PM   #34
Billyburban
The factory hoses wonít that r used in the photo. The inner wheel wells are in the way I cut a section out but it still wonít fit Iím just going to use a CPP AN hose kit itís the same price
Old 01-14-2018, 10:15 AM   #35
Bigdav160
Bigdav160's Avatar
I went the AN line route. The adapters at the steering box will raise the lines requiring trimming of the inner fender to clear.
Also, in my case, because I am running a late model serpentine belt system and my motor is moved forward a couple inches (4WD with 700R4) the distance from the box to the pump is very short (not enough room for an AN tee). The simplest way to handle that return line was to weld an AN bung to the side of the pump body.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 06-05-2019, 09:29 AM   #36
71'tahoe
71'tahoe's Avatar
This is a great thread. I'm getting ready to do this swap on a 67' C-20 and a 67' C6500.
71'tahoe is offline   Reply With Quote
Copyright ©2000 - 2019, vBulletin Solutions Inc.
