Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 05-17-2019, 08:52 PM   #1
chip46wis
Water traps
I cannot keep water out of my airlines----exit from comp goes up 5 feet then down to a water trap and lower drain valve. anyone care to share pics of their GOOD water traps? . I have seen 3-4 lines up and down with individual drains at bottom of each. Help?
chip46wis is offline   Reply With Quote
Old 05-17-2019, 08:59 PM   #2
mongocanfly
Re: Water traps
I use norgen on my main line...works very well...and I have a small separator I use at my paint gun..
Mongo...aka Greg
2013 GMC Z71..daily driver
Old 05-17-2019, 10:21 PM   #3
Foot Stomper
Foot Stomper's Avatar
Re: Water traps
Your water trap needs to much farther from the compressor to be effective. The air coming out of the compressor is very hot and contains water vapor and until the air cools enough for the vapor to turn to a liquid, which will be captured by your water trap.
Move the water trap to the end of the line and you will see results.
So when is this "Old enough to know better" supposed to kick in?
My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989
Foot Stomper is offline   Reply With Quote
Old 05-17-2019, 10:24 PM   #4
Macdaddy1
Re: Water traps
I also use a norgen filter and have 4 lines 5 ft up and down with traps at each down pipe.
Macdaddy1 is offline   Reply With Quote
Old 05-22-2019, 09:45 AM   #5
projectking
projectking's Avatar
Re: Water traps
This
I made a “snake” behind the compressor all back pitched to drain the water to the tank to give me an xtra 30’ of line before my first drop. Your drops need to come out on top so the water isn’t as able to get towards the separator like this:
68 GMC C3500 Longhorn DRW
67 Chevy C10 LWB
90 Mustang Gt
90 Mustang Notchback
projectking is offline   Reply With Quote
Old 05-22-2019, 09:47 AM   #6
projectking
Re: Water traps
Mine drains to the compressor tank and I drain it regularly, not feasible to drain away with the “snake”
67 Chevy C10 LWB
90 Mustang Gt
Old 05-22-2019, 11:38 AM   #7
MP&C
MP&C's Avatar
Re: Water traps
Refrigerant dryer.. done..
Robert
MP&C is offline   Reply With Quote
Old 05-22-2019, 01:01 PM   #8
nsb29
nsb29's Avatar
Re: Water traps
Harbor freight has them at a decent price
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
Also A/C center duck for 65 Chevelle
3-D scanning and printing of rare and obsolete parts
nsb29 is offline   Reply With Quote
Old 05-29-2019, 03:36 PM   #9
theastronaut
theastronaut's Avatar
Re: Water traps
You've got to cool the air down enough to condense the water vapor into a liquid before it can be caught in a water trap. I used a cheap dorm fridge with a copper coil in a 5 gallon bucket to cool the air down, then a normal trap on the outlet. No moisture problems since.
Extra length in the lines and placing the trap farther away from the tank might work ok in the winter, but when it's 90+ in the shop and the lines get heat soaked you're not dropping enough temperature to cool the air by extra line alone. A refrigerated system is necessary in the summer.
theastronaut is offline   Reply With Quote
Old 05-30-2019, 12:59 PM   #10
chip46wis
Re: Water traps
Sorry just getting back--Excellent advice from all ...TY
Old 06-09-2019, 09:23 AM   #11
72c20customcamper
72c20customcamper's Avatar
Re: Water traps
I use this to cool the air as it comes out of the tank, it then goes thru a separator then a filter and finally a desiccant dryer. This is just when I do things outside that its rigged like this with air lines.
Mark
72 c20 custom camper Husky edition,66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark
1969 AMX ,02 Springer. 03 anniversary Fatboy.
81 Honda automatic 1600 miles
2012 Road Glide Ultra 2015 Honda Goldwing
1968 c20 stepside
Old 06-09-2019, 09:27 AM   #12
72c20customcamper
Re: Water traps
I'm looking to get one for my garage air. But I need a new compressor as my old one has sprung an air leak in the tank. It's a rot hole in the base so it's out of commission don't dare use it like that.
Mark
1968 c20 stepside
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
