04-19-2015, 02:48 PM | #1 |
I need suggestion on why a/c pulley is not lining up right.
heres pics of what I have going on. This engine is a 79 350 that I have bought parts for to make it look like it should have in my 69.. The a/c brackets are from a 69 the pulleys are from a 71 or 72 . As you vcan see in the pics I have to "shim" the back of the compressor to get it to line up. all other belts line up just fine. I'm not sure what I have going on here hoping someone may see something wrong and tell me. The shim thing isn't going to work because the top bracket won't line up. If you see or know what's going on here let me know... thanks in advance,
69 step side http://67-72chevytrucks.com/vboard/s...d.php?t=613407 |
04-19-2015, 02:50 PM | #2 |
Re: I need suggestion on why a/c pulley is not lining up right.
a few more
04-19-2015, 02:51 PM | #3 |
1 more
04-19-2015, 07:11 PM | #4 |
Old member
I had a double water pump pulley on the 305 and the AC went on the second puley so you 3 row it should be on the middle pully not the outter 3rd one.
Here is the correct belt line up for a small block. Outside belt is crank and power steering. Middle belt is crank water pump and AC. Inner belt is water, crank and alternator.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
04-19-2015, 07:37 PM | #5 |
Are you sure the pulleys and brackets are for short or long water pump ?
1971 C10 SWB ...project in the works 2000 Camaro SS....weekend warrior/racecar 2005 Caddy EXT....Tow rig |
04-19-2015, 08:16 PM | #6 |
they suppose to be short, but thats what I 'm wondering
04-19-2015, 08:29 PM | #7 | |
04-19-2015, 09:58 PM | #8 |
Old member
From this picture it looks like you need a differant crank pulley setup. Your crank shouldn't have that big gap between the pulleys. They should all be tight and they should line up fine.
04-19-2015, 10:23 PM | #9 |
That's what i'm guessing that too,, but all the pulleys came off the same engine I bought them from a forum member ? I 'm trying to contact him but no luck so far
04-20-2015, 09:14 AM | #10 |
Just heard from the member they are a short w/p set off a 69 c20 ? So if anyone has any idea's let me know
04-20-2015, 09:38 AM | #11 |
GM had so many variations of pulley combinations it's ridonkulous. Single, double, triple, quadruple, A/C, no A/C, P/S, 2wd/4wd, small block, big block.
Typically, for an A/C & Power steering set up you would have a double groove pulley on the W/P and a triple on the crank. The inside is for the Alternator, middle for A/C, and outer for P/S. Move the A/C to the middle and get a new crank pulley. The seller didn't mislead you, the truck it came off of had a different set up. I can't really tell from the pics, but does your crank only have two grooves? It looks to me like the truck your pulleys came from had PS but no A/C.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 04-20-2015 at 10:06 AM. |
04-20-2015, 09:43 AM | #12 |
The crank pulley looks correct to me for a SWP, just wrong "set up." The long water pump crank pulley sits far off the balancer, like this (I converted my truck from a 73+ LWP to correct looking SWP set up):
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
04-20-2015, 10:48 AM | #13 |
The pulley set for a SWP keh27 got from me when I parted out C20 I had awhile back. The AC brackets on my truck looked different from what you are using at least it looks like to me. I wonder, are you using a different balancer perhaps that is not quite as thick? The one that was on my C20 was pretty massive. The threads in the end of the crank snout were bad so I couldn't pull the OEM balancer off.
04-20-2015, 10:51 AM | #14 |
Member #1049
The pulleys you have are for a short water pump setup, its just that your lower inner crank pulley is for a non-ac setup. The pictures that ANDY4639 posted are correct, The grooves that you have your AC belt on in the pictures are originally intended for a smog pump.
You just need a double groove crank pulley like this: http://www.ebay.com/itm/63-64-65-66-...58383c&vxp=mtr |
04-20-2015, 01:27 PM | #15 | |
What I finally ended up doing is getting a FULL set of pulleys off of a truck that wasn't bastardized by one or more previous owners. Since I was planning to add AC I made sure I got them all off of a truck the the general made with AC. That was over 10 years ago. I have never looked back. Long story short, watch the parts board for a fresh part-out and ask to purchase all the pulleys on the water pump and all the pulleys on the crank.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
04-20-2015, 02:23 PM | #16 |
http://67-72chevytrucks.com/vboard/a...5&d=1423780677
This was one of the under hood pics I took. This was a factory AC truck-he opted to not take the AC brackets since he already had those...but, mine are different than he shows. ??? Posted via Mobile Device |
04-20-2015, 02:53 PM | #17 | |
04-20-2015, 04:15 PM | #18 |
My '71 with A/C does not use that top bracket that shows in the PO's photos. If I remember, I will snap a photo this evening.
04-20-2015, 07:35 PM | #19 |
Old member
The pictures I posted are the correct setup for a c-10 small block short water pump with factory alternator, AC, power steering. If you want to mix and match the pulleys that fine but the correct setup is as I showed. The setup you have is for a non AC truck.
Factory AC brakets: This shows the belt routing. Factory AC brackets I took off and sold.
04-20-2015, 10:51 PM | #20 |
thanks everybody for the help
04-20-2015, 11:30 PM | #21 |
I had some time tonight to do a little research ......
Found this thread.http://67-72chevytrucks.com/vboard/s...d.php?t=130114
04-21-2015, 09:16 AM | #22 | |
