04-22-2015, 02:42 PM | #1 |
Pinion angle???
Hey guys, so i pulled the rear axle out to freshen it up a bit (new axle bearings, and fresh paint).. Seeing as i lowered the truck now 5" in the rear, i assume the angle on the pinion also has to be adjusted to the change? If so what is the range it has to be for this type of drop?... The truck is a 70c10 shortbed with a two piece driveshaft, oh and its dropped 3" in the front as well. Thanks
04-22-2015, 02:51 PM | #2 |
Re: Pinion angle???
I bought some of these
https://www.performanceonline.com/19...ar-Suspension/ Not sure if you are running coils or leaf. I bought the 4 degree ones. I haven't installed them yet and from what i've read you want about 4 to 6 degrees. |
04-22-2015, 02:59 PM | #3 | |
Re: Pinion angle???
04-22-2015, 03:41 PM | #4 |
Re: Pinion angle???
04-22-2015, 03:53 PM | #5 | |
Re: Pinion angle???
04-22-2015, 04:20 PM | #6 |
Re: Pinion angle???
http://markwilliams.com/driveshafttech.aspx http://www.macsmotorcitygarage.com/2...e-and-phasing/ heres a couple more sites...
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
Thread Tools | |
Display Modes | |
