12-10-2017, 10:53 AM | #51 |
Re: Barger's 79 FJ40
Well it's next time
Pic #1. This is the Passenger side "A" pillar that was rotted out. Pic #2. The Green/brown on the floor was the O.E. color and this was under the factory coating I removed. On the right side the A pillar was cut out. Pic #3. close up of pillar Pic #4. New piece made for repair. Pic #5. The piece being fit before welding (didnt have a shot of it finished) Till next time Mark
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
12-10-2017, 11:04 AM | #52 |
Pic #1. Drivers side inner rocker was badly rotted so it gets cut out, the black is rust encapsulator The "A" pillar was also rotted and is fixed along with this.
Pic #2. The new piece I made to replace the bad. Pic #3. Fitting the new piece, this will end up having a large hole drilled in it for a drain plug. Pic #4. The final repair. Till next time Mark.
10-26-2018, 08:07 AM | #53 |
UPDATE:
Sorry Guys for the Long Wait!! on the updates, I will jump around with bodywork and primer fairly quick (so not to bore) Pic 1 First rd of primer. Pic 2 After blocking,filler,primer etc Pic 3 The Green material is Fiberal A fiberglass filler I use first Pic 4 Rear floor ribs were Very time consuming!! Pic 5 Final primer. Mark
10-26-2018, 11:17 AM | #54 |
Looks good in primer.
Now on to the painter and then to the building stage? Or am I going too fast here?
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
10-26-2018, 12:58 PM | #55 |
To be honest kees I'll let you guys vote.
The build is already complete and went home, so I have All the ammo I need to show as much as you would like to see. That being said...would you rather move forward (bypass to paint)and assembly or more primer detail? Let me know Mark
10-26-2018, 05:57 PM | #56 |
I am good with whatever you share...and paint then assembly is always exciting. Shiny new stuff!
10-26-2018, 08:13 PM | #57 |
Looks good...I'd also like to see it all...
10-29-2018, 05:35 AM | #58 |
Yep I’d like to see all you do.
I’m learning..... Thanks!
10-29-2018, 08:07 AM | #59 |
Here are some shots of the rear doors and the rot that needed my attention.
Pics 1-5 I wont go into detail (don't need to explain with these) Mark
10-29-2018, 06:08 PM | #60 |
Nice! That edge had to have been difficult to weld. Did you back it with copper?
10-29-2018, 09:53 PM | #61 |
No I didnt, It welded pretty good actually.
Was time consuming though.
10-29-2018, 10:01 PM | #62 |
Pic 1 Bottom of door all metal finished.
Pic 2&3 Bottom of door sill needs repair,so I made a new piece to be welded in. Mark
11-01-2018, 09:57 PM | #63 |
Just a few shots of some parts after bodywork and primer to move things along.
11-04-2018, 09:21 AM | #64 |
Update:
Unfortunately while I was transferring pictures from one phone to another I lost 2000 pics! So I wont be able to show all the things I wanted. Here are the start of paint (none during)That being said I really wanted to show all the shots from under the body as I sprayed the undercoat. I call the color swamp water/baby poo brown Pic 1. Backside of front fender Pic 2. Topside just after painting. Pic 3. During wetsanding Pic 4&5 After polishing.
11-04-2018, 10:07 AM | #65 |
i like the "swamp water do-do" brown....i bet it looks good
11-05-2018, 08:45 AM | #66 |
Greg, It's one of those colors that grow on you!
Mark
11-05-2018, 01:29 PM | #67 |
Awesome work again!
I like the color too, fits the car just right!
11-05-2018, 06:28 PM | #68 |
Thank You sir!
11-05-2018, 06:38 PM | #69 |
Update:
Pic 1. Trans cover Pic 2. Side panel Pic 3. Passenger side front & rear doors Pic 4. Rear door wetsanded Pic 5. All rubbed and polished. Mark
11-05-2018, 11:12 PM | #70 |
Looks good Mark!
11-06-2018, 08:24 AM | #71 |
Thanks Doug
11-06-2018, 08:37 AM | #72 |
Nice work!
11-06-2018, 07:26 PM | #73 |
Thanks GreenLee
11-06-2018, 07:33 PM | #74 |
Pic 1. Here is the way I get panels prepped during wetsanding.
I use fineline tape on all the edges to protect them from burning through. Pic 2-3 after wetsanding and polish Mark
11-08-2018, 01:30 PM | #75 |
Really nice!
Some orange pinstripes would also be nice
