Old 12-30-2014, 06:20 AM   #1
72Chebby
Lowering & Driveshaft Length
Hi guys, a little help if you can. I did a 3/5 drop on my 72 longbox. Springs and shocks. Do I need to do anything with driveshaft length or panhard bar adjustment. Never adjusted a panhard before so don't know proper procedure. Seems to me driveshaft angle and length would be affected to some degree. U-joints and carrier are all new on the 2 piece driveshafts. Th400 tranny. Thanks.
72Chebby is offline   Reply With Quote
Old 12-31-2014, 09:47 AM   #2
PGSigns
PGSigns's Avatar
Re: Lowering & Driveshaft Length
Drive shaft will be fine. You will need to check the pinion angle once you have it back on the ground. The track bar will need to be adjusted once it is back on the ground to center the rear end back up. You will need to install an adjustable track bar as the stock one is not adjustable. I used the super track bar from Early classics and it worked well.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 01-03-2015, 10:38 AM   #3
72Chebby
Thanks Jimmy. That answers most of it. Any advise on the track bar adjustment procedure?
Terry
Old 01-05-2015, 03:41 PM   #4
64chevmn
I dropped my rear 6-inches with lowering springs and adjustable trac bar (5-inches in the front) and I had to shorten my driveshaft by 3/4 of an inch to get the slip yoke to fit the way it should.
64chevmn is offline   Reply With Quote
