Old 10-17-2019, 11:38 PM   #1
Short 3/4
Seat Lowering
I know there is a company making lowering brackets for the 67+ trucks, but can't find any info on lowering the stock bench in my 65.
Anybody done this with a kit or otherwise?
Thanks,
Tom
65 short stepside K10
292-SM420-T221
8 lug closed D44 front
NoSpin HO72 4.10 rear
Short 3/4 is offline   Reply With Quote
Old 10-18-2019, 07:47 AM   #2
PGSigns
PGSigns's Avatar
Re: Seat Lowering
The bracket from a 67 should work. I had a 70 seat in my 66 for a while when I rebuilt my seat. Biggest difference in the seats was the later seat did not fold forward.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 10-18-2019, 09:59 AM   #3
rickylucy
Re: Seat Lowering
I found a link to Full Custom Fabrication that sells new seat brackets that lower your seat about 2 inches. Direct bolt on that took less then 30 minutes.
https://squareup.com/store/full-custom-fabrication/
rickylucy is offline   Reply With Quote
Old 10-18-2019, 09:59 AM   #4
Android04
Android04's Avatar
Re: Seat Lowering
Here you go. I have them and love them; I'm 6ft 2".
https://squareup.com/store/full-cust...rackets-tall-2
Android04 is offline   Reply With Quote
Old 10-22-2019, 02:26 AM   #5
Short 3/4
Re: Seat Lowering
Thanks to all for the info.
Tom
292-SM420-T221
Old 10-22-2019, 05:47 PM   #6
63burban
Chevy addict
Re: Seat Lowering
Why would anyone want to lower the seat ?
63burban is offline   Reply With Quote
Old 10-23-2019, 12:19 AM   #7
Short 3/4
Re: Seat Lowering
Was just about to order a set when I noticed that the only way to adjust the seat appears to be with slots in the floor mounting bolts. Unfortunately my wife also drives the truck, so that would not work. Am I missing something, or is there another way to do this?
292-SM420-T221
Old 10-23-2019, 12:22 AM   #8
Short 3/4
Re: Seat Lowering
See post #4
292-SM420-T221
Old 10-23-2019, 03:02 AM   #9
Mack B
Mack B's Avatar
Re: Seat Lowering
Originally Posted by Short 3/4 View Post
See post #4
I'm only 5'10" and feel my line of sight through the windshield is too high, but at the same time I feel like I'm raising my knees to my chin to work the clutch and brakes.
To those that's done this, did it make the pedals any more difficult to operate?
Mack B is offline   Reply With Quote
Old 10-24-2019, 11:51 AM   #10
63burban
Chevy addict
Re: Seat Lowering
I am 6' 4" and all I did was install 1/2" spacers under the front seat mounts. It's more about position than leg room.
Old 10-24-2019, 12:04 PM   #11
Android04
Android04's Avatar
Re: Seat Lowering
Well I am 6ft 2" and the steering wheel rubbed my legs so bad I had to drive like I was having a baby. haha
Lowering the seat changed everything and I love it.
Old 10-24-2019, 12:40 PM   #12
Clatterville trolley
Clatterville trolley's Avatar
Re: Seat Lowering
There are 3 different sets of brackets / sliders that are different heights spread over the 6 years of trucks 1967-1972. I suspect that the person who "drove like they were having a baby" had a taller set mixed with a seat that was originally with another shorter set of brackets . . .
If you do a search on the 67-72 pages there is a post with very clear photos and descriptions of the three different set sizes.
PayPal 1windyridgeboy@gmail.com
Clatterville trolley is offline   Reply With Quote
Old 10-24-2019, 05:59 PM   #13
damnyankee36
damnyankee36's Avatar
Re: Seat Lowering
My new seat foam was about 1" taller than the old foam. I assumed it was because the old foam had collapsed. But my skinny legs still hit the bottom of the steering wheel and I felt too tall and I'm short in the upper body.
I wanted to keep the seat brackets factory so my plan was to use a long saw to cut a 1" section out of the middle of the foam and glue it together. That way I didn't have to duplicate the upper or lower shapes.
I didn't do it as I sold the truck before I had a chance.
damnyankee36 is offline   Reply With Quote
Old 10-25-2019, 10:04 PM   #14
DrKrankenstein
Re: Seat Lowering
I was curious about this too for these c10's, I also have a '47 I had to do some seat foam work and seat bracket fabrication to get work, not comfortable but it works , at 6' 7" I struggle with these older trucks.
The issue I have is my knees above steering wheel and into the dash, I also have to duck to see out of windshield. I need to do something with this C10
Thank you for the replies
DrKrankenstein is offline   Reply With Quote
Old 10-28-2019, 04:46 PM   #15
Short 3/4
Re: Seat Lowering
As I am having the seat redone as well, I talked to the guy recovering it and he said he can basically do what you said. He has a special foam saw that can do a nice clean cut. Says this is a common problem and he has done this a lot, so problem solved and I don't loose adjustment.
292-SM420-T221
Old 10-28-2019, 06:49 PM   #16
damnyankee36
Re: Seat Lowering
Cool! Let us know how it turns out!
