07-02-2018, 11:28 AM | #1 |
hood to cowl rubber seal?
are the cowl seals much different from 78 and a 81, need one for a 78 but found a new one for a 81 hour from here.
07-04-2018, 12:10 AM | #2 |
Re: hood to cowl rubber seal?
yes enough 73-80 81-87 c/k
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
