Old 03-20-2017, 03:31 PM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
How are the lower radiator brackets removed and installed?
Any help appreciated, see captions please...........Thanks
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 03-20-2017, 03:33 PM   #2
67ChevyRedneck
67ChevyRedneck's Avatar
Re: How are the lower radiator brackets removed and installed?
I can't even remotely see those, even on my 23" screen.
If I recall correctly, you remove the rubber pad (it just pulls out) and there's 2 rivets under there. You can rivet, bolt, or screw them back in, up to you.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 03-20-2017, 03:44 PM   #3
RodnRudy
RodnRudy's Avatar
Looks like you have the longer 4 row brackets. Just bend the lip of the core support down where it is hitting the bracket and it should lay flat as it is supposed to.
Phil
"Money is only a tool to create and achieve what you want most in life"
PayPal: rodnrudy@comcast.net
RodnRudy is offline   Reply With Quote
Old 03-20-2017, 03:44 PM   #4
71CHEVYSHORTBED402
Sorry, 900 pixels usually works.
Whoops, I didn't think to remove the pad first. How about that positioning? It's as if they're the wrong brackets. The core bushings are toast, but I wouldn't think that would be it.
Tony
Old 03-20-2017, 03:47 PM   #5
71CHEVYSHORTBED402
It is a four core radiator. Hmmmm.........You figure that means it wasn't 4 core from factory, or this is the product of their labor?
That's twice in a week I've had reason to purchase a torch.
Tony
Old 03-20-2017, 03:50 PM   #6
Mryan
Active Member
I modified the front so the bracket could lay flat, then riveted the new one back in place. I did not have to do this with the two row, but the new three row did exactly what you show in the picture when trying to place the mount. I took a small vise grip and bent the ridge down and it has worked well.
Mryan is offline   Reply With Quote
Old 03-20-2017, 06:17 PM   #7
FirstOwner69
FirstOwner69's Avatar
Torch??? As stated above, use vice grips to bend the lip toward the engine down. Generally, that's what the factory did for the 4-row radiators. Also, drill the rivets and replace them with small bolts of your choosing as stated above. I used flat head 1/4" stove bolts as short as I could go with the heads up.
FirstOwner69 is online now   Reply With Quote
Old 03-20-2017, 06:34 PM   #8
71CHEVYSHORTBED402
Dumb question of the day (pull pad for surprise). Yeah rivets and thanks for the help.
Looks like there are two bracket position options in the core support. Mine were on the outside, so that's where I bent the core support using a crescent wrench. Crossing my fingers the new radiator doesn't want the inner.
It doesn't require much of a bend, though I could go a hair more. Fits like it should as stated...........Thanks a bunch.
The mess is one reason I no longer buy cheap batteries.
Tony
Old 03-20-2017, 06:36 PM   #9
71CHEVYSHORTBED402
HA!@........Okay, not a torch. It bends easily. But I need one for a bench seat rod.
Tony
Old 03-20-2017, 06:42 PM   #10
RodnRudy
RodnRudy's Avatar
You can see from your first pic that the radiator was sitting wrong on the lower pads from the way the pads are crunched down. Good job on the fix.
Phil
Old 03-20-2017, 06:49 PM   #11
71CHEVYSHORTBED402
Good point and thanks for the props.........Next up is the acid caked battery box. Can't find the garbage fast enough.
Tony
Old 03-20-2017, 06:50 PM   #12
randy500
The factory usually beds the core support down like you did, surprised it wasn't installed correctly in the first place.
randy500 is offline   Reply With Quote
Old 03-20-2017, 08:10 PM   #13
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
subscribed
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 03-20-2017, 08:14 PM   #14
71CHEVYSHORTBED402
Yeah, figures they were stoned when it was added. I misspoke about a "clip" in the bracket. It's just a tab that's SUPPOSED to insert into the hole in the support.
Misspoke about junking the battery box too. I scrubbed acid off enough to justify keeping it around a while. The sides are great. I did get a one piece after-market from Manes, which is a nice box. I guess the original is three pieces. Tack welded, I'm assuming.
Tony
Old 03-20-2017, 10:21 PM   #15
67ChevyRedneck
Looks like there are two bracket position options in the core support. Mine were on the outside, so that's where I bent the core support using a crescent wrench. Crossing my fingers the new radiator doesn't want the inners.
GM had 3 radiators with 2 different brackets. GM had a narrow bracket and a wider bracket.
The standard radiator was a 2 row. It used the narrow brackets and it also used those "inside" mounting holes your referring too.
The 3 row used the narrower brackets as well (if you've seen a factory two row, they look funny because they use the same tanks as the 3 row, but have one less core, so the tanks stick out like 1/2" past the core). The three row is wider than the 2 row and uses the same "outside" bracket holes as the 4 row.
The 4 row uses the wide brackets and the outside bracket holes.
Jesse James
Project "On a Dime"
Old 03-20-2017, 11:26 PM   #16
71CHEVYSHORTBED402
Just realized there are two provisions for a radiator, but only on the RH side. Good stuff, thanks for the info. I don't recall seeing a two row, but I'll look one up. Engine matters I suppose. I figured four row was standard for BBC, but probably figured wrong.
Tony
Old 03-21-2017, 12:12 AM   #17
67ChevyRedneck
They look weird. My 67 had one. It seems they were mostly used on I6 manual trucks.
Jesse James
Project "On a Dime"
Old 03-21-2017, 12:45 AM   #18
71CHEVYSHORTBED402
I've seen those. They do look a little off - almost "incomplete".
Something else I noticed about the bottom brackets tonight. If your 46 year old dry climate bushings are shot like a certain Custom Deluxe, there's no getting a nut on the LH side. In other terms, I'd be drilling anyway. A nut would have dug into the bushing. Don't know how long the rivets are, but it probably was against the bushing.
Tony
