Old 02-01-2018, 11:03 PM   #1
'65 chevy lover
How difficult to remove and install new freeze plug
Upon further inspection, the freeze plug appears to have a crack in it, not leaking where it mates to the crank case. So, going to remove this plug(had planned to do this anyway)and replace. Question is, how difficult is it to do this?
'65 chevy lover is offline   Reply With Quote
Old 02-01-2018, 11:33 PM   #2
Rusty63
Rusty63's Avatar
Re: How difficult to remove and install new freeze plug
I usually push in one side,then grab it with needle nose pliers finish pushing it in then pull it out,just so it doesn't drop out of sight,have had good luck that way,but others may do it differently!
Rusty63 is offline   Reply With Quote
Old 02-02-2018, 08:00 AM   #3
The Rocknrod
Too Cool For School
The Rocknrod's Avatar
It's in the engine and drive-train forum section - http://67-72chevytrucks.com/vboard/s...d.php?t=435786
Master Chief, US Navy, Retired - He ain't no drag Papa's got a brand new bag
1964 C10 Step-side Short Bed - In Progress
2009 2500HD Duramax LTZ
1948 GMC Panel
1956 Big Window Stepside
1953 5 Window Chevy Stepside
New Seat Foam for Bench Seats?
Old 02-02-2018, 10:11 AM   #4
jayoldschool
Drill a screw into it, grab screw with vise grips, tap one side to dislodge, extract.
jayoldschool is offline   Reply With Quote
Old 02-02-2018, 03:43 PM   #5
'65 chevy lover
What about the cuttings/particles from drilling the hole? Seems like that could be bad on the water pump.
Old 02-02-2018, 04:20 PM   #6
mongocanfly
ive always used a big screwdriver and hammer....hit it on the edge with the screwdriver and itll spin sideways in the hole..then a pair of channel locks to pull it out..just like this....
https://www.youtube.com/watch?v=y9yzjoUYmKw
Mongo...aka Greg
1981 c30 lq9 nv4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598
1955.1 ls3 tr6060...(under construction)(on hold)
2013 gmc z71. (daily driver)
Old 02-02-2018, 11:59 PM   #7
Captainfab
60-66 Nut
I usually knock them inwards and get nit a little sideways. Then grab it with a pair of vise grips and leverage it against the block to pull the freeze plug out thru the hole.
Old 02-03-2018, 01:55 AM   #8
'65 chevy lover
Thanks to all for the replies. I checked out a few YouTube videos and, it looks like it shouldn't be real difficult to remove and replace.
Old 02-04-2018, 12:20 AM   #9
'65 chevy lover
I attempted to remove the freeze plug. On the 2nd wack with the hammer, the entire back of the plug popped off and fell into the block and, I was unable to retrieve it. I was able to remove the round piece of it without problems. So now what do I do? Can the flat piece remain in there without causing problems? I posted couple pics of the round part of the plug although they are kinda hard to see.
Old 02-04-2018, 10:44 AM   #10
geezer#99
geezer#99's Avatar
It likely won’t hurt anything or go far. Go fishing with a coat hook.
Over the years I’ve found several pieces of them in water jackets when I had to replace a block heater.
Old 02-05-2018, 12:01 PM   #11
GRX
GRX's Avatar
Agree. Probably won't hurt a thing. Have actually seen a few engines where someone pushed every single plug in instead of extracting them. Characteristic "tink tink" when rolling the block on the engine stand.
To state the obvious ... clean that hole well with sandpaper before install.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Copyright ©2000 - 2019, vBulletin Solutions Inc.
