Old 02-11-2018, 04:12 PM   #1
VetteC10
Replacement Distributor
Hi, new the forum, I just purchased a 66 C10 with a 327, and looking to replace the distributor with an upgraded electronic model. I tried an HEI and a Petronix, and neither would fit due to firewall clearance. Does anyone know what brand/model will clear the firewall?
Thanks in advance.
VetteC10 is offline   Reply With Quote
Old 02-11-2018, 06:22 PM   #2
Re: Replacement Distributor
I had a factory HEI and a replacement from Speedway in my 64. I could not put it in with the cap on though. Once in place , I could put cap on and had clearance. It was close, but never hit. Just could not insert or remove it with the caps inplace.
1981 GMC High Sierra SWB Stepside
2006 GMC Sierra 1500 SWB W/T
Board Vendors
It's scary when you start making the same noises as your coffee maker.
Old 02-11-2018, 06:25 PM   #3
VetteC10
I removed the cap and rotor on both the HEI and the Petronix, and both are hitting the firewall. the HEI almost got in if I wanted to force it, but the petronix is longer, and I can't even get the shaft down into the hole.
Old 02-11-2018, 06:36 PM   #4
jayoldschool
Use the stock distributor, small cap, and use an internal Pertronix kit. That's exactly what I did on my 65 327 in my Impala. Works perfectly, I run much more advance, starts immediately, has much more power. I'm still on points on my 65 truck, but will switch it over some time.
jayoldschool is offline   Reply With Quote
Old 02-11-2018, 07:02 PM   #5
VetteC10
I was considering that. the distributor i took out looks like it has an older conversion in it, but since I bought it not running, was wanting to upgrade if possible.
Old 02-11-2018, 07:02 PM   #6
sprinter11r
sprinter11r's Avatar
I have a 64 with HEI and no clearance problems. could your cab mount bushings be collapsed?
sprinter11r is offline   Reply With Quote
Old 02-11-2018, 07:05 PM   #7
65chevysub
65chevysub's Avatar
I did the same as jayoldschool did. I used a stock distributor with the Pertronix ob my 65 Subyrban with a 283. Been running that way for atleast 20 years. Hard to believe I know but its still going.
65chevysub is offline   Reply With Quote
Old 02-11-2018, 07:06 PM   #8
Macdaddy1
I have a 327 in my 65 and have to take the cap off to install distributor and then put cap on afterward. It is tight but just makes it.
Macdaddy1 is offline   Reply With Quote
Old 02-11-2018, 07:13 PM   #9
VetteC10
good question about the cab bushings. I almost had the HEI in, but since it was new, I didn't want to bag it up (or the firewall) forcing it. I didn't need much more space to get it in, so maybe the cab bushings are the cause. I am sure they are old.
Old 02-11-2018, 09:39 PM   #10
jayoldschool
A third option is the F body or the S10 small cap remote coil HEI.
Copyright ©2000 - 2019, vBulletin Solutions Inc.
