Old 02-03-2018, 11:28 AM   #1
tjc
tjc's Avatar
new rebuild 454
fired up my newly rebuilt 454, about 1973 series. have 50 psi on gauge for oil pressure but I don't see any oil coming to the heads. any ideas.
Tom in Iowa
68 L88 C10
68 4x4 C10 soon
tjc is offline   Reply With Quote
Old 02-03-2018, 01:13 PM   #2
geezer#99
geezer#99's Avatar
Re: new rebuild 454
Hopefully you primed the motor first.
If you did you’d have seen no oil then.
Did you prime it?
Old 02-03-2018, 05:03 PM   #3
hans2
Re: new rebuild 454
Priming helps the top end get oil before initial firing, but only if it's done with the right tool (or old dist modified to do the job). If he didn't prime, it only means it's going to take a few extra seconds to see oil out of the pushrods. Not a big deal at all if built with assembly lube.
To the OP - how long did you let it run after initial firing?
hans2 is offline   Reply With Quote
Old 02-03-2018, 06:36 PM   #4
nikwho
nikwho's Avatar
Re: new rebuild 454
I like priming the oil pump, if for no other reason than to make certain that the oiling system is working properly prior to start up.
How did you confirm that no oil is coming to the heads? With valve covers off? How long was engine running before you shut it down due to not seeing oil come to the heads?
'68 GMC - BBC/TH400
'59 Apache - SBC/700r4
'53 GMC 350/th350, S-10 swap & 3 linked - SOLD...
nikwho is offline   Reply With Quote
Old 02-03-2018, 10:07 PM   #5
tjc
tjc's Avatar
Re: new rebuild 454
I did prime the engine with a priming tool for about 2 minutes and did not see any oil to the rocker arms. I started the engine and let it run about 5 minutes, oil psi at 50. but still no oil from rocker arms. today I loosened all rocker arm nuts 1 full turn. primed again and got oil thru 1 rocker arm. restarted and got nothing. yes engine was assemble with lube and oil was poured over all rocker arms before priming or starting. will pull pan tomorrow.
Tom in Iowa
68 L88 C10
68 4x4 C10 soon
Old 02-03-2018, 10:19 PM   #6
geezer#99
geezer#99's Avatar
Re: new rebuild 454
Could be a cam bearing in wrong.
What are you gonna check on the bottom end?
Old 02-04-2018, 11:02 AM   #7
tjc
tjc's Avatar
Re: new rebuild 454
The last time I started it, it did not have oil pressure. 15 years ago I had a oil pickup tube rotate above oil level. it was also a BB. I am just going to start over.
Tom in Iowa
68 L88 C10
68 4x4 C10 soon
Old 02-04-2018, 12:55 PM   #8
tjc
tjc's Avatar
Re: new rebuild 454
OK after priming with drill I can see a small amount of oil coming thru the push rods onto the rocker arms, and still have 55 psi oil gauge. How do I trouble shoot this?
Tom in Iowa
68 L88 C10
68 4x4 C10 soon
Old 02-04-2018, 09:45 PM   #9
kwmech
Re: new rebuild 454
It usually takes me about 8-10 minutes with priming a big block to get all the air out of the galleys and lifters, especially with the larger pushrods
Old 02-04-2018, 09:45 PM   #10
Mike C
Mike C's Avatar
Re: new rebuild 454
It's probably OK. I pre-oiled my 427 last year and it took 20 minutes for oil to come out of all the pushrods! I was more than a little concerned. Spent a few minutes consulting the all-knowing Google and it seems that is not unusual.
I think you are OK, but search Google for Big Chevy slow to prime threads and read and see if it doesn't apply to you.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-06-2018, 07:06 AM   #11
Ironangel
Ironangel's Avatar
Re: new rebuild 454
Did you install a new oil pump on the rebuild? If so I wouldn't worry to much especially if your using a weak 3/8" drill motor to spin the pump. In this cold weather it's going to take longer to pump up. Welding or brazing the pick up tube to the pump will eliminate the chance of it vibrating loose and sucking air...I also tap and plug the spring loaded bypass on the spin on filter adaptor. PS. Use a 1/2" drill motor if you have one and if you rotate the crank it will help fill the lifters and get oil up to the rockers.
Michael Hill, "Two Seventy Two's"
Ironangel is offline   Reply With Quote
Old 02-06-2018, 01:32 PM   #12
tjc
tjc's Avatar
Re: new rebuild 454
I took the intake off and can see oil and air bubbles coming out of the lifters. and I have 55 psi on the oil gauge. Oil is making its way to rocker arms, I was expecting to see oil squirt out like the small block chevys.. I will re-start later this week. Thanks for all the info
Tom in Iowa
68 L88 C10
68 4x4 C10 soon
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
