Old 02-10-2018, 11:31 PM   #1
fisherman420
Castrol GTX Magnatec for flat tappet break-in?
As the title states, I've been seeing lots of commercials for the new Castrol GTX Magnatec oil. They say it protects your engine for the crucial first 20 minutes of run time which would suggest it is suitable for a flat tappet cam break in time. Just wondering if anyone has any experience with this oil for a flat tappet cam break in as I cannot find any zinc/zddp content info.
My 1950 Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=720858
fisherman420 is offline   Reply With Quote
Old 02-11-2018, 12:00 AM   #2
truckdude239
truckdude239's Avatar
Re: Castrol GTX Magnatec for flat tappet break-in?
I wouldnt use any full synthetic for breakin
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 101kmiles
2002 Honda Accord 4 door With 275k(sisters car)
2003 Honda Accord 109k( brothers car)
2002 Sububran 5.3 225k
2000 Tahoe 5.3l 369k
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 02-11-2018, 01:19 AM   #3
71cheyennesuperlongb
71cheyennesuperlongb's Avatar
I dont think full syn oil would have enough zink products to help with break in.With what a engine cost Joe Gibbs break-in oil would be money well spent, and probably not much mone money.
'71 Cheyenne Super LWB - Second Owner in 39 Years!
'70 CST/10 SWB - Soon to be Daughter's truck when finished
71cheyennesuperlongb is offline   Reply With Quote
Old 02-11-2018, 04:34 PM   #4
Alex V.
Alex V.'s Avatar
Synthetic or not isn't the determining factor for ZDDP content - emissions regulations are. ZDDP isn't friendly to emissions equipment like catalytic converters so there's a continual push to reduce the amount of it in oil. For instance, the current API service spec SN will generally have a bit less than the previous spec, SM.
Using synethetic oil during break-in has no benefits that I can think of - it's slicker and protects better so it can actually hinder break-in which is the intentional, controlled wearing of parts to one another. I would either use an oil specially intended for break-in on flat-tappet engines, or a name brand conventional with break-in/high ZDDP additive. While I've never used it Amsoil makes an SAE-30 break-in oil, and I've been very pleased with their other products.
Alex V.
1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs.
1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue.
Alex V. is offline   Reply With Quote
Old 02-11-2018, 07:24 PM   #5
panhead59
I have used amsoil break in oil with success. It is actually their only oil that isn t synthetic
panhead59 is offline   Reply With Quote
Old 02-12-2018, 02:50 PM   #6
fisherman420
I've used traditional oil with comp cams break-in oil and also had success using mobil delvac diesel oil and break-in additive, just curious if there are any possible success stories with the new oils and flat tappet camshaft life without any break-in additives or break-in specific oil. Until I hear some success stories I'm going to keep spending the whopping $8 for additive on top of conventional oil
Old 02-12-2018, 03:13 PM   #7
toolboxchev
ZDDP is not the only thing your engine needs for break in. A oil with a high film strength is most important from my research.
Read here:https://540ratblog.wordpress.com/
It has been covered here before. So in a nutshell use this, Valvoline VR-1 Racing Oil.
70k on a top end rebuild that was not going to work according to a certain number of sources speaks to me.
toolboxchev is offline   Reply With Quote
Old 02-14-2018, 12:11 AM   #8
ElKotze
ElKotze's Avatar
Cam Brake-in instructions that came with my crate engine states "Do not use synthetic oil for initial cam break-in".
'64 C10 LWB, 283, 5speed
'68 C10 LWB, 350, 4speed
'69 C20 Custom Camper Longhorn, 350, 4speed
'72 C20 Cheyenne Super
ElKotze is offline   Reply With Quote
Old 02-14-2018, 02:54 AM   #9
'68OrangeSunshine
'68OrangeSunshine's Avatar
Non-detergent straight 30 weight oil, plus GM EOS and lots of black cam lobe on assembly. for break-in and first 500 miles. Then detergent oil.
Forget the fancy stuff, it ain't for our vintage technology.
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
