Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 06-27-2008, 10:13 AM   #1
blazer2007
lookinf gor torque strap ideas
I might put a torque strap on a b.b. 78 truck,looking for ideas and where to bolt it to,should I bolt it on the side by the header or on the front of the head
blazer2007 is offline   Reply With Quote
Old 06-29-2008, 02:13 AM   #2
COMP
Re: lookinf gor torque strap ideas
i have put them on the front of the head,,,,you going to add a band around the tail shaft of the trans to ?
COMP is offline   Reply With Quote
Old 06-29-2008, 10:21 AM   #3
cdowns
cdowns's Avatar
in most applications you'll find a frame is most rigid in the firewall area so i've always had torque straps off the rear of the engine or the bellhousing
theres alot more flexing of the frame up by the front crossmember sort of defeating the purpose of the torque strapo//thats why on these trucks with the factory recall they installed the torque strap at the rear
