Old 11-25-2015, 12:07 AM   #1
baggedbigblock
mounting bags on porterbuilt trailing arm
I have a non Porterbuilt C notch and a have standard firestone 2600 bags, not the sleeve style I see above the axle. I am waiting on my trailing arms to come in.
I want to mount them forward of the axle, but as close as possible. I am looking for a clean install. Thanks in advance for any pictures.
baggedbigblock is offline   Reply With Quote
Old 11-28-2015, 12:09 AM   #2
baggedbigblock
Re: mounting bags on porterbuilt trailing arm
Bump
Old 11-28-2015, 11:03 AM   #3
SCOTI
SCOTI's Avatar
What year/model truck are you installing the PB Truck-Arms on? His arms locate the spring in the original location which is slightly in front of the rear axle unless you're purchasing one of the 'Extreme DM rear kits' (which does relocate & use sleeve type bags.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-28-2015, 12:46 PM   #4
baggedbigblock
I have a 66 swb with a big notch from suicide bro. I think I am going to mount in front of axle with a bag plate on arm and inner frame
Old 11-28-2015, 01:18 PM   #5
SCOTI
SCOTI's Avatar
Again..... original placement is in front of the rear-end.
If you're trying to lay the frame on the ground by relocating the bags farther forward on the T/A & making new upper mounts inside of the frame, I would contact 'Porterbuilt Fab'. Get your info from the source. He would be the best guy to answer the question.
Good luck....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-28-2015, 01:21 PM   #6
baggedbigblock
Will do, thanks
Old 09-26-2017, 04:51 PM   #7
mel knippson
SO what happened .. what did yo do ?
mel knippson is offline   Reply With Quote
Old 09-26-2017, 04:52 PM   #8
mel knippson
so what did ya end up doing ?
