05-14-2016, 01:16 PM | #26 |
Re: '60-'66 Body On A '73-'87 Frame
I like the height on the yellow C-10 just fine
Current/past Chevy/GMC trucks: 1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner |
05-14-2016, 01:34 PM | #27 |
Funny--It looks like a tk and most don't like it. Being old i guess i like a tk that look like a tk lol! Slammed tks are fine also, and a lot of work to build. A little lower in the front and it would look stock. Just build them guy's & gal's.
1961 chevy K10 my build is------------61K10 build |
05-14-2016, 09:03 PM | #28 |
But Found Her 25yrs Later!
I don't think it's so much if it'll look okay, but more so - what's the point?
There's no advantage over just using the correct frame.
05-14-2016, 11:25 PM | #29 |
60-66 Nut
Exactly!
A lot of work for no real gain. In fact IMO the trailing arms and coil springs ride nicer than the '73+ leaf springs.
04-03-2017, 11:30 PM | #30 |
Bumping a bit of an old thread. I have a very rusty 1973 K20 that I'm thinking of body-swapping to a 60-66 or 67-72 body on the 73 frame. My frame is fine and I just need the front half (cab, fenders, doors, etc.). It's a flatbed and I will keep it that way. I'd appreciate any additional links or advice from the esteemed veterans here.
04-04-2017, 12:12 AM | #31 |
60-66 Nut
Do you have the means to fabricate the cab mounts on the frame? What is the law in Colorado regarding a frame and body swap. IE the frame and body having a different VIN.
04-04-2017, 10:27 AM | #32 |
Here is mine, it is a '62 body on a '73 frame. I cut the '62 cab mounts off the original frame, and re-used them on the new one. I also cut the front few inches of the frame rails off and spliced them into the '73. The front bumper wouldn't fit correctly on the new frame. The biggest headache is the frame rails kick up under the back of the cab, so you need to raise the cab, or channel the back of it to sit over the frame rails.
In the end it seemed like an easy way to get disk brakes, power steering, and newer parts. There are some pictures in this post that show the bottom of the cab. http://67-72chevytrucks.com/vboard/s...0&postcount=48
"Always try to make the best part you can with the skills you have. If it isn't good enough throw it away and make another. Every time you make a part your skill will increase and you'll make a better part than you were capable of making before." Lil John Buttera |
04-04-2017, 10:47 AM | #33 | |
Any hints from those have gone before will be greatly appreciated. I do have the means to fabricate the cab mounts, though I don't really know what that entails until I know the respective positions of the 73 cab mounts and those of the earlier model. I do think I like the 60-66 body a little better, especially the GMCs. Do any of the particular model years hold up better from a rust perspective? Are 60-66 better/worse than 67-72? |
04-04-2017, 10:48 AM | #34 | |
04-04-2017, 12:21 PM | #35 | |
http://www.semasan.com/page.asp?cont...olbox&g=SEMAGA ron |
04-05-2017, 07:18 PM | #36 |
Here is my 64 on a 84 k10 chassis. pretty simple straight forward swap on a 4x4 as long as you want a 3" body lift and go with a flatbed due to frame length difference
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis 1964 GMC K10 383cu in/sm465/twin stick np205 1965 Chevy C60 |
04-05-2017, 07:27 PM | #37 | |
Thanks. Your rig is pretty much what I have in mind. (But with a plow on the front.) |
04-05-2017, 08:05 PM | #38 | |
I ditched the stock cooling fan for electric My steering column was broke up inside so I ended up putting a van column in. That is something else for you to consider
04-05-2017, 08:06 PM | #39 |
I also used the cab mounts from the 64 frame and welded them on the 84 frame
04-05-2017, 08:17 PM | #40 |
Couple newer pics
04-05-2017, 08:24 PM | #41 |
09-25-2017, 12:03 AM | #42 | |
09-25-2017, 12:07 AM | #43 |
I'm looking to do the same swap onto a k10 frame. I have taken the mounts off the 66 frame and have them ready to bolt onto the 83 k10 frame. But I was wondering if you had the measurements for the height off the frame of the radiator support mounts in front. And we're there any specific issues you ran into when doing the swap that I need to watch out for?
Posted via Mobile Device |
09-25-2017, 11:39 AM | #44 |
The rear of the cab is the first spot that will hit the new frame. I would set the cab on the frame with some 2x4's on the frame to start with, and adjust from there.
Also, save the front foot of the old frame. The bumper bolts directly to it, and you can weld it to the new frame. (Same with the rear bumper if your going to use that too)
09-25-2017, 11:01 PM | #45 | |
60-66 Nut
If this question is directed to me, no I do not have any measurements. This is not my truck. I helped build that truck for someone else over 25 years ago. The issues I ran into is that it is a lot of work and a PITA.
09-27-2017, 12:08 AM | #46 |
This was my 2 owner 69,xxx mile 63 short fleet custom on a 84 K10 frame. I sold it about 8 months ago to a guy in Canada.
Remember: "When seconds count, the Police are only minutes away". Thx, Billy B. |
09-27-2017, 12:38 AM | #47 |
I dont see nothing wrong with that.
09-27-2017, 01:05 AM | #48 |
"Back of the 73+ Frame sits at least 3 inches higher than the 60-66 frame. " that would make it look like the red one to me
ron |
09-27-2017, 09:19 AM | #49 |
The point we keep leading back to is; there is no point in using the newer frames. Just use the original frame. There is nothing, absolutely nothing to gain using the newer frames.
If anything, it's bass ackwards to not use the original frame. Just bolt up the newer crossmember, and be done with it. Not to mention we should keep the matching VIN's.
09-27-2017, 10:02 AM | #50 | |
61 apache |
