07-01-2018, 12:04 AM | #1 |
Questions on axel swap
Picked up a 76 chevy 4x4 shortbed the other day and it has some money into the suspension. My question is can I swap it out with a 71 blazers axel and suspension?
Any input would be great, thanks. |
07-01-2018, 03:11 PM | #2 |
Re: Questions on axel swap
not sure on the leaf springs, but the front axle should bolt right in, rear you will probably have to move the spring perches
1970 1/2 ton 4x4 4spd Suburban 1972 K10 350/700R/205/ Sniper EFI Daily Driver Sold 1971 K5 on 35s Traded 1972 K5 3/4 ton PROJECT Sold |
07-02-2018, 08:43 AM | #3 |
Front axle is a direct replacement. Rear axle requires relocating both the spring perches and the shock mounts. Rear springs should be 52” on a short square body and are direct replacements. Some squares had 56” springs but I don’t think 1/2 ton trucks did, but never say never.
The front springs are not interchangeable. They are too long for a 69-72.
