02-22-2023, 05:25 PM | #1 |
LS3 water neck and radiator hose
Want to make sure this water neck will fit on the BOTTOM outlet on my LS3
Also - any suggestions for the upper and lower radiator hoses ?
1972 K5 Build - plans - LS3-6L80e-One Tons..... 1971 CREWMAX Build.....at body shop for couple more years |
02-22-2023, 05:53 PM | #2 |
Re: LS3 water neck and radiator hose
I don't know about the thermostat housing but in regards to the radiator hoses I make a wire pattern and then hit the parts stores. Most will let you look thru them to find what you need.
Just a note. The earlier LS engines had a "fixed" thermostat in the housing. The later LS housings have removeable thermostats. |
02-22-2023, 06:27 PM | #3 |
That listing shows 1997 - 2020 LS engines, but they changed the thermostat design in 2014 or so. Maybe they made the new ones universal? I had to mill open the diameter where the thermostat sits about .050" on the diameter to get the earlier version to work with the later thermostat.
02-22-2023, 09:12 PM | #4 |
Does the thermostat typically go into the lower hose or the upper ?
02-22-2023, 10:17 PM | #5 |
Always in the lower on LS engines. See pic of my 68 C10 LS swap.
SBC had the stat in the upper hose. |
02-23-2023, 06:13 PM | #6 |
impressed you got the coil installed without the spindle on.
02-23-2023, 09:54 PM | #7 |
Good thing about lowering springs that it makes it so much easier to install the spring and then the spindle.
03-16-2023, 09:48 AM | #8 |
Back to the top
Thermostat housing is on now just to find the upper and lower hoses I have searched a few times - seems most suggest the Upper hose to be a Gates 21439 but that has the water neck that comes up and out at like a 40 degree angle, my LS3 has it coming out totally different. I also couldn't find a clear answer on if the lower hose Gates 21439 had the correct end sizes ? Neither of the autoparts stores had them in stock or I would have tried
03-16-2023, 01:37 PM | #9 |
I've had to splice pieces of hoses on some of the ones I've done..so that could be a option
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 03-16-2023 at 07:24 PM. |
03-16-2023, 06:14 PM | #10 |
I replaced the lower outlet with a straight version. It was on my car, but it works well.
03-16-2023, 07:09 PM | #11 |
I think the lower hose will work, ordered a GAtes 20931.... be here next week
03-19-2023, 01:28 PM | #12 |
Roto Reuter thats the name...
Yes that thermostat housing will work. I used the same one on my LS3. I would also use Mr. Gasket Thermostat, PN 6368.
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
