Old 01-10-2019, 12:21 PM   #1
cebra
Pros/Cons: Installing Harness before Engine
I am debating whether I want to hook up my harness (standalone harness from BP Automotive) to the sensors on the motor before dropping it in or after? My thought is after to keep from accidentally routing the harness some place I can't get it out if needed or pinching it when dropping the motor in...as I look at it, it may be tough to route once the motor is in due to the number of wires running near the bottom of the motor. Thanks for advice.
My Daily Driver Build: http://67-72chevytrucks.com/vboard/s...d.php?t=755668
cebra is offline   Reply With Quote
Old 01-10-2019, 01:55 PM   #2
Macdaddy1
Re: Pros/Cons: Installing Harness before Engine
I installed mine after I dropped in the motor and then played with wire routing. However, my cab was off at the painters so it was easy on just a frame.
Macdaddy1 is offline   Reply With Quote
Old 01-10-2019, 03:42 PM   #3
1971Stepside
Almost Satisfied
1971Stepside's Avatar
I put my BP Automotive on after the engine was in. Cab is on, but no fenders. I have plenty of room to work the harness where I want it. It will come off and go back on at least two more times before I am done.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 01-10-2019, 04:16 PM   #4
mongocanfly
mongocanfly's Avatar
I would wait til after install...the only plug that's hard to get to is above the starter....leave the starter off til you get it plugged and the rest is easy....no sense fighting the harness while your installing the engine
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 01-10-2019, 05:42 PM   #5
cebra
Interesting, I would have never thought to leave the starter off for install as pulling one off a Silverado at the JY was a pain. Are they not as difficult to install on the C10 as they are to get off the Silverado? I have to drop my motor in with all sheet metal installed (doing it at night on the roof of my parking garage). Can you get that plug on after the starter is installed?
Old 01-10-2019, 05:44 PM   #6
cebra
Sounds like after is the consensus.
Old 01-10-2019, 05:46 PM   #7
1971Stepside
Almost Satisfied
I put mine on with starter in place, but I had the header removed. With the starter and manifold in place it would be tough to do
Old 01-10-2019, 07:12 PM   #8
sprint_9
sprint_9's Avatar
Keep in mind you can only pass the harness one way through the hole if you use the grommet provided with the bp harness and its 2 1/4 hole or what ever it is.
For example, putting the harness on the engine and then dropping it in the frame and stuffing the ecm side of the harness into the cab wont work, the hole is too small for the plugs to fit. You can get 1 or 2 plugs in, but not all.
If not using the grommet and passing though the hole then it would be no issue either way.
sprint_9 is offline   Reply With Quote
Old 01-10-2019, 08:55 PM   #9
nsb29
nsb29's Avatar
That’s only if your ECM is going to be in the cab
nsb29 is offline   Reply With Quote
Old 01-11-2019, 12:29 PM   #10
sprint_9
sprint_9's Avatar
if not using the grommet and passing though the hole then it would be no issue either way.
Originally Posted by nsb29 View Post
that’s only if your ecm is going to be in the cab
fyi
