Old 10-29-2012, 01:08 PM   #101
gottattooz
gottattooz's Avatar
Re: Captain America 68 short/fleetside
The front's are 15 x 8 1/2 and the rears are 15 x 10. The rear kit was $399.00 and $40 shipping. http://www.ebay.com/itm/1969-1970-ch...item4cebd3fe2b
-Josh
1967 Buick Special wagon
1968 Jeep Wagoneer
1958 Chevy Panel Truck
2017 Suzuki M109R
gottattooz is online now   Reply With Quote
Old 11-03-2012, 03:05 AM   #102
gottattooz
gottattooz's Avatar
I got the stock rear shocks installed, and now the rear goes all the way down to the bump stops. I got my front end rebuild kit installed today. Now all I should need is an alignment, and the Captain should be taming the roads in the very near future. I did notice, with the bags all the way down, the left rear tire is at the outer edge of the wheel well, and the passenger rear is tucked in a few inches. I'll have to check the differences when it's set at my desired cruising height, and I might have to get an adjustable panhard bar. More money, I guess.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 11-30-2012, 01:53 PM   #103
gottattooz
gottattooz's Avatar
I installed front and rear sway bars. MAN, what a difference!!
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 06-01-2013, 08:46 PM   #104
gottattooz
gottattooz's Avatar
I started grafting my Cadillac SRX tail lights onto my spare bed. MY friend Charlie is a great fabricator, so I'm more of his helper than anything/
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 06-01-2013, 09:17 PM   #105
69 MOD
69 MOD's Avatar
That turned out pretty damn good!!
Chad
'71 GMC 2500 Custom Ol Blue
'72 Custom Deluxe Highlander Stuffed Olive
'73 Trans Am
'13 Silverado 2500 Duramax Storm Trooper
69 MOD is offline   Reply With Quote
Old 06-02-2013, 11:28 AM   #106
bruceman1968
bruceman1968's Avatar
Josh, That looks Great! Can't wait to see it finished out.
CHEVY/GMC VIN DECODERS
bruceman1968 is offline   Reply With Quote
Old 06-29-2013, 08:52 PM   #107
gottattooz
gottattooz's Avatar
I've been messing around with the grille on the truck. MY friend gave me the grille, and I cut out the center bar, cut up and repurposed the stainless trim, and remounted the stock turn signals.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 07-23-2013, 11:17 PM   #108
gottattooz
gottattooz's Avatar
MY latest conquest was buying a 2004 GMC Savana 2500 to rob the 4.8l engine and transmission, the wiring harness, dash cluster, and any other stuff I can graft onto the 68.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 07-24-2013, 12:03 PM   #109
Hardesty454
Hardesty454's Avatar
Looking good. I like the mods I'm seeing!
Rob
1971 c10 - ground up in progress
Tripp's Speed Shop Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=589750
Hardesty454 is offline   Reply With Quote
Old 07-29-2013, 01:14 AM   #110
Superdrag67
I like the outside of the box mods! Keep it up.
Superdrag67 is offline   Reply With Quote
Old 11-28-2013, 11:31 AM   #111
gottattooz
gottattooz's Avatar
So....I got the 4.8l and trans sitting in the engine compartment, and my exhaust came in. It's a stainless steel exhaust, including headers, high flow cats and a y-pipe into a 2bolt flange. man, is it pretty.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 11-29-2013, 08:34 PM   #112
Operatorfailure
Looking good. You will love the LS swap, best thing I have done to my truck yet. Oh, and the 4.8's love boost, who wouldn't love a turbo'ed Captain America?
Operatorfailure is offline   Reply With Quote
Old 04-16-2014, 08:09 PM   #113
gottattooz
gottattooz's Avatar
Just a quick update. I've been chipping away at the little details, hoping to fire the engine and drive down the road. I've got the engine and trans mounted, new driveshaft, fuel pump installed, with new lines run. My favorite is the air suspension. I mounted the compressor behind the cab on the driver's side, The air tank is nestled inside the frame, opposite the exhaust. I installed an air ride level sensor, so no matter how light or heavy I load the truck, the ride height will stay the same. No sagging ass end, even with a loaded trailer. The fuel pump wiring is the next obstacle I have to tackle.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 04-16-2014, 08:42 PM   #114
bruceman1968
Nice work Josh, engine looks great and the grill you did is super slick. I really like the grill. Can't wait to see it in person.
Old 04-24-2014, 07:50 AM   #115
gottattooz
gottattooz's Avatar
Well, the captain is up and running. I did three test drives, each one a little longer than the next. Feeling good about my progress. Still have to wire up the wiper motor and clean up the cabin area inside. Bad news, i took the ignition key out, and now i can't find it. It figures as soon as i get her up and running, I lose the keys!!
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 04-27-2014, 12:23 PM   #116
FL71C10
Looking good, Josh. You got that motor installed and wired up pretty quickly!
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 04-27-2014, 01:07 PM   #117
gottattooz
gottattooz's Avatar
Ok, so I've got drivability issues resolved. I am loving the way it drives and handles.
I have 235/70R15's on the front, and they rub the inner fenders when I hit small bumps. Wednesday, I'll swap out to 235/60's and get an alignment since I put the 2 inch lowering springs in the front (with 2 1/2" drop spindles).
I adjusted the ride level in the back so it didn't have such a rake on it. I'll fine tune that when I get the bed installed.
If you notice the trim around the grille missing, that's because my dad was being a smart ass and backed into the front clip. It missed the grille, but caught the trim with the bottom of the receiver on the trailer hitch. If anyone has a crusty trim hoop for a 67-68 grille, let me know what you want for it.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 04-27-2014, 01:14 PM   #118
gottattooz
gottattooz's Avatar
Here's how she looks in the engine compartment. I need a heater core box that isn't all eaten up like the one I have so I can atleast have defrost, but that's not a big deal at this time. I'm loving the stainless steel headers and the flowmaster exhaust.
The dash panel is currently ziptied to the harness running across the steering column, but I have a friend who does stereo installs and fiberglass work who said he'd help me get that squared away.
And the last pic shows just how bare bones the truck is. No radio, no a/c, no carpet. Just bucket seats and a steering wheel. I love it. I want to go for another ride right now!!
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 04-27-2014, 09:52 PM   #119
NastyBuzzard
NastyBuzzard's Avatar
Thumbs down Re: Captain America 68 short/fleetside
More pics on how u got dash, cluster and steering column in!! Did u have to send ECM off to delete vats and all using the steering column and such??
NastyBuzzard is offline   Reply With Quote
Old 04-27-2014, 09:57 PM   #120
bruceman1968
Josh, Looks great. Glad to hear you are driving it around. Nice work!
Old 04-27-2014, 10:02 PM   #121
colgad
colgad's Avatar
-Josh
I have a few grills you can take a look at. I am in Lutz. PM me for the address. Then again you may remember it! :-)
Dave
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline   Reply With Quote
Old 04-28-2014, 06:14 AM   #122
gottattooz
gottattooz's Avatar
Currently, I have the stripped down cluster fastened to the wiring harness that goes over the steering column with a pair of nylon zip ties at the bottom. I'll get some pics of the steering column mounting for you.
As for the ECM, I didn't touch anything. The plan was to unplug everything, swap it over, and then plug it all back in, and that's what I did. I disabled the airbag system, and didn't use the ABS module. The airbag light and ABS light are on in the dash, but that's it.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 04-28-2014, 07:46 AM   #123
NastyBuzzard
-Josh
Wow, so no need to send off ecm or anything? That is interesting. I would love some more pics. Even though my truck is a 1987 I think it should be similar ordeal.
Really trying to figure out how to swap in the fuel tank from the 01 as well.
So you didn't do a standalone setup, right? You swapped everything from the original fuse box to the newer one? That is what I am wanting to do!
Sorry to threadjack I am just full of questions!!
Thanks!
Old 04-28-2014, 08:12 AM   #124
gottattooz
gottattooz's Avatar
I swapped the entire wiring harness from the van to my truck. I have the fuse panel under the hood, and the fuse panel in the cab. The van headlight and tail light harnesses, a/C and radio plugs, even the tow/haul button is mounted in the dash. I had a check engine light, but i fixed an exhaust leak at the header, and the light went out. I transferred the stock fuel pump into my tank behind the axle and extended the wiring and fuel lines. Even mounted the evap canister for the fuel system on the frame.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 04-28-2014, 08:25 AM   #125
NastyBuzzard
-Josh
Where are the pictures and write ups on how to do all this?!?!? That is definitely what I want to do. Tow/haul button and all. Wow, I know that took some time. I'd love to have all my lights and everything wired to relays in the stock relay box from the 01. That would be wicked!!
Stillt trying to see if I can find info on mounting the whole plastic fuel tank though. How did you swap in the stock fuel pump assy into your existing tank? Thats neat.
