10-15-2011, 01:36 AM | #1 |
Is it a good deal?
I was looking for a frame with a stepnotch already welded in and came along this one. I am not sure what the going rate is for frames. This one is boxed and z'ed. The guy wants 200 for it. I haven't seen it in person yet, but here are some pics. When I do go look at it, what should I make sure to look at?
10-15-2011, 01:46 AM | #2 |
VA72C10
Re: Is it a good deal?
200 is a great deal but I question the a-arms and wonder if it's square or not...
Also, the rear notch probably could use some cross bracing.... also, what motor was it set up for? Looks like big block mounts (?) which you'd have to change if you're going sbc...
Looking for a 67-72 swb or blazer project in or around VA. |
10-15-2011, 02:06 AM | #3 | |
As for squareness, I am assuming that you are talking where it's got the goofy square tubing welded up? |
10-15-2011, 03:06 AM | #4 |
looks like the entire cross member is welded to the frame, that might make it kind of difficult if you need to change any component.
A arms need to go, they are too sketchy looking.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 |
10-15-2011, 03:12 AM | #5 |
VA72C10
Wondering if the frame is square itself....measure front to rear diagonally and from the front crossmember ends to the frame rails and from the rear of the notches to the rear frame rail....
10-15-2011, 03:26 AM | #6 |
that looks a little sketchy id start with a stock frame even if its more
70 SWB STEPSIDE 70 BLAZER 09 challenger |
10-15-2011, 08:36 AM | #7 |
Ya, i would not trust someone elses fab work for something like this, you would be much better off getting a stock frame and doing the work yourself
68 SWB Fleet 383 |
10-15-2011, 08:45 AM | #8 |
I would pass on this. Don't like commenting on others work however I would pass on this without hesitation.
Run Forrest Run Last edited by mbgmike; 10-15-2011 at 09:58 AM. |
10-15-2011, 08:49 AM | #9 |
Just a car guy
I would take that straight to the recycler.
There is a reason why its not under a truck.
1955 belair Blown Pro Street cruiser 1971 Camaro Pro Touring 1973 Vega Drag Car 1970 C20 tow rig |
10-15-2011, 09:54 AM | #10 |
yep recycler is the place for that abortion
10-15-2011, 10:59 AM | #11 |
That frame is only worth is weight in scrap...pass.
"Some of my finest hours have been spent on my back veranda, smoking hemp and observing as far as my eye can see." - Thomas Jefferson 72 C10 SWB "Work in Progress" |
10-15-2011, 11:06 AM | #12 |
Think about it, someone put a ton of time and money into that frame. And now they are basically giving it away? Why? Probably cause it's junk. I agree with the earlier posts, this kind of work is better handled by yourself or farmed out to someone reputable. Not purchased second hand where you know nothing about what was done!
Run away, I would Posted via Mobile Device
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
10-15-2011, 01:16 PM | #13 | |
72 Cheyenne Super LWB 350/350 Factory A/C Tilt/Posi White/Med Red/White(on the way) 72 Custom Deluxe Burb(Arizona truck)Nice interior Great patina Project Patina Azul http://67-72chevytrucks.com/vboard/s...d.php?t=467668 |
10-15-2011, 03:46 PM | #14 |
these guys said it best!! too much time in that not to be using my friend!!
1971 rs camaro under the knife ls3 6 speed swap 1970 396 big block shorty fleet 67 clone 2010 rs/ss camaro |
10-15-2011, 03:56 PM | #15 |
VA72C10
while I agree with the above comments....check to see if the spindles are drop spindles and in good shape. Plus, the frame looks fully boxed. If it was square i'd buy it for the frame, spindles, and brakes, and notch, (and possibly crossmember after checking out how it works with steering...and cut off/scrap the rest...
(spindles/brakes are worth over 200 if it's drop spindles)
10-15-2011, 04:01 PM | #16 |
C/10 junkie
Looks like hammer marks on this side of the step notch.
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" |
10-15-2011, 04:25 PM | #17 |
Pass!!!!
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
10-15-2011, 08:33 PM | #18 |
This is exactly why I posted on here first. I knew it's the place to get honest answers. Thanks everybody.
