Old 12-29-2013, 07:25 PM   #1
1971'Burb
2WD to later model 4x4?
What is good donor truck for a 4x4 frame upgrade for a 1970-1972 suburban? I like the 88-98 trucks but they are not the same wheelbase design. Anybody done it? Thanks.
1971'Burb is offline   Reply With Quote
Old 12-29-2013, 07:31 PM   #2
BennettGM
BennettGM's Avatar
Re: 2WD to later model 4x4?
I used a 86 3/4 suburban under my 2wd 72 suburban. My guy shortened the frame approx 3 inches.
72 Suburban 3/4 ton 4X4
BennettGM is offline   Reply With Quote
Old 12-29-2013, 07:54 PM   #3
1971'Burb
Cool!
I suppose there isn't anything even close to just bolt on.
Crawl, walk, run, fly... what's next?
Old 01-01-2014, 07:54 PM   #4
RANDY COX
RANDY COX's Avatar
Nope if it were that easy everybody would be doing it, Like me...
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 02-18-2014, 09:23 AM   #5
CUCV2
CUCV2's Avatar
How different are the frames from 2wd to 4wd? The B52 kit from DIY4X
http://diy4x.com/cart/index.php?rout...product_id=122
seems like a good way to convert the front suspension to 4wd if they are similar where the spring perches mount. I know that you can mount 73-91 Chevy lift springs on those (they are 48" long) if you use the frame mount end hole closest to the axle. The axle will end up forward about an inch though.
CUCV2 is offline   Reply With Quote
Old 02-18-2014, 02:34 PM   #6
JJorgensen52
Simple? What's simple?
JJorgensen52's Avatar
The frames are actually remarkably similar. It can be done with a 4x4 donor truck if you're not afraid of cutting into the frame.
I'm about to do this on my '72 C3500 with an '87 K30 donor truck.
CURRENT
'50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build
'63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos
'66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos
'69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!)
'72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh
'99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily)
'99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs)
SOLD
'71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder)
JJorgensen52 is offline   Reply With Quote
