Closed Thread
Old 02-24-2018, 10:05 PM   #6351
stevenfromtexas
stevenfromtexas's Avatar
Re: What did you do to your truck today? Chapter II
Originally Posted by 197D_C10 View Post
I had some new shoes put on the truck today.
hey brother, is that the 506 medium blue? i love your color!!!
Steven
'67 SWB, 250ci, 3OTT.......this is my first build......
I wonder if my grand kids will say, "I would give anything to have my grand dads 2005 Chevrolet Z71"
stevenfromtexas is offline
Old 02-24-2018, 10:36 PM   #6352
Brofle1402
Worked on my motor swap which is about over.
Brofle1402 is offline
Old 02-25-2018, 02:07 PM   #6353
iriereggaeman
iriereggaeman's Avatar
replaced a number of worn steering/suspension parts with high-quality parts from Moog. It really makes a difference in the steering - things are a bit stiff - but hope it'll work it's way out in the next couple week. Aiming for a pothole here and there to help it along.
iriereggaeman is offline
Old 02-25-2018, 09:04 PM   #6354
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
I don't like working in the garage with the doors closed, and we finally got some nice weather today, so prepping for blast & powder coat. They say no grease and no grease they get. I probably spent 5 hours cleaning this cross-member.
Put the frame on wheels. I imagine it will high center on and off the auto transport, but at least it's easier to lift this way. Worst case scenario I add a center "axle", but I probably won't.
On a side, I read a shop describing how they spent 2000 hours on a full restoration. I'd like to know how they did that
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline
Old 02-25-2018, 09:43 PM   #6355
ripper70
ripper70's Avatar
Installed my battery box,trans cooler,and fuel tank after polishing them. Digging buffing compound out the crack of my ### lol! Also installed back glass
1970 K20
1967 Blown Stepside
2016 Chevy 2500 Duramax
1989 Jeep Cherokee
1995 S-10
2014 Infinity Q-50 AWD
1970 Chevy K20 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=634164
1967 stepside rebuild
http://67-72chevytrucks.com/vboard/s...d.php?t=684913
Shop build http://www.garagejournal.com/forum/s...d.php?t=225559
ripper70 is offline
Old 02-26-2018, 01:20 AM   #6356
Metaldoc
Metaldoc's Avatar
I personally did all the work on my truck and have over 1500 hrs in it. I didn't paint the outer shell, left the original patina, and could have added another 500 to 800hrs on top. It's not hard to add up time. Keep it up looks good. My engine cradle was full of grease and grass from an animal.
Metaldoc is offline
Old 02-26-2018, 03:18 AM   #6357
JMD
JMD's Avatar
Took some doing, and it was a little unorthodox, but it's out.
My build thread: http://67-72chevytrucks.com/vboard/s...96#post7439296
JMD is offline
Old 02-26-2018, 12:11 PM   #6358
197D_C10
197D_C10's Avatar
Thanks bro. I forget the exact name of it, but its a Lexus color. My son picked it out.
197D_C10 is offline
Old 02-26-2018, 08:07 PM   #6359
RodnRudy
RodnRudy's Avatar
I stuck the pistons, torqued the rod caps and installed the cam and timing chain/gear. That cone type ring compressor I got from Summit works slick.
Phil
"Money is only a tool to create and achieve what you want most in life"
PayPal: rodnrudy@comcast.net
RodnRudy is offline
Old 02-26-2018, 08:11 PM   #6360
RodnRudy
RodnRudy's Avatar
Couple more, can't load more than two at a time, pics might be too large?
Phil
RodnRudy is offline
Old 02-26-2018, 11:47 PM   #6361
ZEKE68
ZEKE68's Avatar
Finished the throttle linkage and some of the fuel line. Plumbed the P/S vacuum line. Installed the fuel pump. Set the radiator and shroud.
1968 SWB Step Side, Big Block, 4L80E , Running!
ZEKE68 is offline
Old 02-27-2018, 12:24 AM   #6362
Metaldoc
Metaldoc's Avatar
I just pulled mine apart down to the pistons, they were still good. Looking great.
Metaldoc is offline
Old 02-27-2018, 03:16 AM   #6363
3757chevy
3757chevy's Avatar
I hauled a hundred pounds of aluminum cans to the recycler , took up more space than I thought .
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline
Old 02-27-2018, 07:10 AM   #6364
hamjet
hamjet's Avatar
That looks like a 60s 327 with that road draft tube casting in the block with the oil baffle still in place, been a while since building those. memories....
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline
Old 02-27-2018, 10:28 AM   #6365
VWNate1
VWNate1's Avatar
Thumbs up Still 'Hauling The Mail'
I LOVE your truck ! .
-Nate
VWNate1 is offline
Old 02-27-2018, 01:31 PM   #6366
3757chevy
3757chevy's Avatar
Thanks Nate, I've this one twenty years now it's been good to me.
MIKE
Old 02-27-2018, 01:31 PM   #6367
Metaldoc
Metaldoc's Avatar
numbers matching 283 from my 67
Metaldoc is offline
Old 02-27-2018, 06:41 PM   #6368
Metaldoc
Metaldoc's Avatar
Hey man , have got a pic of your step side with the side showing the black ralleys with spinners against the blue paint. I 've been toying on painting mine black from silver. One hundred pounds of empty aluminum beer cans?
Thanks Derek.
Metaldoc is offline
Old 02-27-2018, 08:19 PM   #6369
Gokart Mozart
Walked away after nearly stripping a brake fitting.
Gokart Mozart is offline
Old 02-27-2018, 09:54 PM   #6370
3757chevy
3757chevy's Avatar
No Metaldoc mostly soda cans and some v8 juice energy drinks and that. I couldn't save beer cans long enough to save up 10 pounds. uck
MIKE
Old 02-28-2018, 11:06 AM   #6371
3757chevy
3757chevy's Avatar
Some times when I go to the recycler in the summer the smell of all the beer cans is almost unbearable.
MIKE
Old 02-28-2018, 11:47 AM   #6372
3757chevy
3757chevy's Avatar
Only side pic I could find this morning Derek.
MIKE
Old 02-28-2018, 02:18 PM   #6373
HO455
HO455's Avatar
That brings back memories. When I was 12 or so the neighbor kid and I got a deal with the local Elks that his mom managed. She would bring the cans home in her truck and we would get to smash them, turn them in and keep the cash. We smashed about hundred pounds a month. Then we take them down to the recycler on our bicycles. We did it for years. It got easier when we got our license's. But never realized the true benefit until years later when mom told me she never could tell if I had been drinking since I had smellled like beer for years.
RIP Bob Parks.
1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F2 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo
HO455 is offline
Old 02-28-2018, 06:17 PM   #6374
3757chevy
3757chevy's Avatar
Stale beer cans are the worst. Pop cans are sticky and summer time swarming with bees, just can't win.
MIKE
Old 03-02-2018, 01:59 AM   #6375
Metaldoc
Metaldoc's Avatar
Perfect thanks, I like the blacked out look better than the silver.
Metaldoc is offline
Closed Thread
