08-25-2017, 10:59 PM | #1 |
Distributor is moving out of its zone
Alright
When I drive the truck multiple times the timing moves and starts to choke down? I am so confused on this as I have tried to think of some things that could cause this anyone have a clue?
1971 GMC Sierra 1959 GMC 100 |
08-25-2017, 11:36 PM | #2 |
Post Whore
Re: Distributor is moving out of its zone
the distibutor itself is moving or just the timing is getting off?
08-26-2017, 07:15 AM | #3 |
what engine and dist?
08-26-2017, 07:18 AM | #4 |
270 engine.. The timing is getting off or both. Im not really sure but when
I turn the distributor back to where it needs to be the truck runs fine
1971 GMC Sierra 1959 GMC 100 Last edited by SCHRUMGMC; 08-26-2017 at 07:26 AM. |
08-26-2017, 08:06 AM | #5 |
Post Whore
is the hold down clamp tight? if you have to keep turning the dist back to the same position each time it sounds like the clamp isn't holding
08-26-2017, 11:34 AM | #6 |
Must have that Famous Optional Floating Distributor Bet your Hold down is Shot
08-26-2017, 12:08 PM | #7 | |
Hollister Road Co.
The second clamp is for the fine tuning, The flat one with the degree notches. This is called an Octane selector. Its sole function is to advance or retard the timing a few degrees according to the octane of the gas you were running. Main timing is done by the collar clamp mentioned above. Frist set the octane selector to the center line matched to the line on the block. tighten that screw. Loosen the screw on the collar and set the timing pointer to the ball on the flywheel and clamp the collar tight. If its loose the dist. will rotate on its own and get out of time. The screw is sometimes hidden behind the grease cup on the side of the dist. If it pings a little or you want a little more power you adjust the octane selector in what ever direction you need. |
08-26-2017, 03:50 PM | #8 |
The distributor is supposed to move a little due to the Vacuum Advance but I don't have a hold down clamp and never have.
08-26-2017, 07:56 PM | #9 |
Hollister Road Co.
You should have all this, if not your missing parts
08-26-2017, 09:29 PM | #10 |
I just looked and I have all of that except for the spring or whatever that is
right there on the Vacuum advance
08-26-2017, 11:32 PM | #11 |
Hollister Road Co.
Post a picture of what you have it would be easier to tell if its missing something
08-27-2017, 08:01 AM | #12 |
I will when I get off of work
08-27-2017, 08:44 PM | #13 |
See, I have everything.. I am thinking the collar thing must be loose?
08-27-2017, 09:30 PM | #14 |
Hollister Road Co.
This screw is most likely loose
08-27-2017, 11:05 PM | #15 |
I've tried tightening it as tight as I could get it
08-27-2017, 11:59 PM | #16 |
Hollister Road Co.
can you turn it by hand with it tight? the only other part that could cause this is the pin that holds the gear on the shaft has sheared.
08-28-2017, 01:09 AM | #17 |
Do they reproduce these Distributors?
08-28-2017, 09:51 PM | #18 |
Hollister Road Co.
You can get a rebuilt for rockauto but It may just be a $0.50 roll pin that needs replacing.
08-30-2017, 12:30 AM | #19 |
Thank you
