Old 11-16-2011, 12:41 PM   #76
Igorsgonemadd
Re: crew cab short bed build " clifford"
Yeah I'll post some later. I just bought it. It's completely stock, has a factory camper on it, running boards, stock height. I got a good deal on it, I think. It's an 87, tbi, 89000 original miles, two owners, power everything, cruise, everything works even the ac, no rust, no dents, no cracks in dash. Paid 3450
Igorsgonemadd is offline   Reply With Quote
Old 11-16-2011, 01:17 PM   #77
rs72z
rs72z's Avatar
Yep, you got a heck of a deal.
rs72z is offline   Reply With Quote
Old 11-16-2011, 01:19 PM   #78
rs72z
rs72z's Avatar
I started on the fenders today. Started on the worst one first. It had a squirrels nest built half way up the rear of the fender.
Old 11-16-2011, 09:30 PM   #79
rs72z
rs72z's Avatar
Patch panel in and first coat of filler on.
Poor dakota had to give up some metal for the patch panel.
Old 11-16-2011, 09:33 PM   #80
scottco
scottco's Avatar
Looking good !!! How did your frame work turn out ???
scottco is offline   Reply With Quote
Old 11-16-2011, 09:35 PM   #81
rs72z
rs72z's Avatar
Epoxy primer on, waiting on it to flash to spray some high build. hopefully my other fender will be in next week.
The bed will be ready for long board with 180 next week then reprime for final sand.
Hopefully both fenders will be primed by Friday. Making some progress.
Old 11-16-2011, 09:39 PM   #82
rs72z
rs72z's Avatar
I still need to finish welding it. I need to take a good welder home from work, my home depot Lincoln 180 ain't welding worth a crap. I still need to mount the bed to see how much of the one ton frame needs to be cut off of the rear.
Old 11-16-2011, 10:59 PM   #83
rs72z
rs72z's Avatar
High build on.
Old 11-16-2011, 11:03 PM   #84
Conundrum
Conundrum's Avatar
Nice build!
Looking forward to seeing this one together.
74 GMC SWB Project "Sin-thia" Static Dropped 8"f/10"r
http://67-72chevytrucks.com/vboard/s...d.php?t=460030
97 GMC reg cab short bed, 4.3V6 / 5spd, daily driver
220,000 miles, all stock for now
Conundrum is offline   Reply With Quote
Old 11-17-2011, 10:28 AM   #85
rs72z
rs72z's Avatar
Originally Posted by Conundrum View Post
Nice build!
Thanks.
Old 11-17-2011, 08:59 PM   #86
scottco
scottco's Avatar
Looks like great progress!!!
Old 11-19-2011, 04:01 PM   #87
rs72z
rs72z's Avatar
Change of plans on the color.
I shot the firewall today, so i can start getting the engine installed.
What do yall think of the color? Sunset pearlescant orange, same color thats on my race car. I am going to two tone it with sandstone.
Old 11-19-2011, 05:39 PM   #88
mrhino
love the color, should look great two toned
mrhino is offline   Reply With Quote
Old 11-20-2011, 12:29 AM   #89
Devillusion
Devillusion's Avatar
tuning into this one, doing more a less the same thing with mine....just I am taking alot longer than you are appearantley...lol. And I spliced a 59' Impala steel dash into mine as well.
Project is looking great....keep up the great work.
1967 K30 4x4/12v Cummins/getrag/D60/D70/355s
1967 GMC suburban 4x4/LS swap 5.3/4500/205/10 bolt/14 bolt full floater
1963 C10 reg cab long box
1970 Chevelle
1968 Biscayne 2dr post
"...there is no excuse for what I am about to do, but dangit....it's gonna be fun!"
Devillusion is offline   Reply With Quote
Old 11-20-2011, 11:13 AM   #90
rs72z
rs72z's Avatar
Old 11-20-2011, 11:16 AM   #91
rs72z
rs72z's Avatar
Well, i can now confirm that you need to cut 4" off the rear of a 1 ton frame.
Old 11-20-2011, 11:19 AM   #92
rs72z
rs72z's Avatar
Bed on and all the gaps look good, tires are centered in the openings.
Old 11-20-2011, 11:23 AM   #93
rs72z
rs72z's Avatar
Couple of shots of the door gaps. First one is the drivers front where i welded some filler in to close up the gap, second one is the passengers side it needs some work also.
Old 11-20-2011, 01:14 PM   #94
Conundrum
Conundrum's Avatar
Looking good man. I like the change in color choice as well.
Old 11-20-2011, 02:06 PM   #95
Maxxd07
Maxxd07's Avatar
Wow this thing is gonna be cool as he11!
Couple 80s
Couple 70s
One 68
Maxxd07 is offline   Reply With Quote
Old 11-20-2011, 06:43 PM   #96
SCOTI
SCOTI's Avatar
Nice!
I took a couple of pics of those wheels if you'd still like to see them. Camera batt died & wouldn't allow uploading them....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-20-2011, 07:59 PM   #97
rs72z
rs72z's Avatar
Engine and trans sitting in place. I still need to pull it back out to modifiy the passenger side mout to clear the a/c compressor bracket. then it's in for good.
I made alot of progress this weekend, it's gonna give me a big head start on getting alot more done during my vaction after turkey day.
I would like to have it running in the next two weeks.
Old 11-20-2011, 08:05 PM   #98
scottco
scottco's Avatar
Wow... !!! Your kickin butt !!! Looks great.............
1964 C10 SWB original
1970 SS El Camino
1964 Impala SS
http://67-72chevytrucks.com/vboard/s...d.php?t=649951
Old 11-21-2011, 12:59 AM   #99
SCOTI
SCOTI's Avatar
Before you modify the frame, check on your a/c options to see what's compatible w/the OE compressor set-up. many have to switch to aftermarket compressors to work properly from the research I did when investigating the costs surrounding a 6.0/4l80e swap.
A good option for an aftermarket a/c set-up w/a Sanden compressor that works w/the remaining OE accessory set-up w/o having to cut the frame is this one.....
http://www.kwikperf.com/lsx_ac.html
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-21-2011, 08:42 AM   #100
rs72z
rs72z's Avatar
I'm not going to cut the frame, just add a plate to the back of the stand and slide the mount back and redrill the holes on the stand and on the adapter. Then i will get some fittings for the compressor from docs blocks.
Thanks for the info though.
PM sent.
