02-23-2020, 06:40 PM | #1 |
Water temp sensor
Does anyone make a water temp sensor that will screw into the head on the passenger side rear of an LS1 that I can wire into a gauge ?
If not what have others done to get water temp to your gauges ?
48 CJ2A 63 1500 GMC (LS1 w/ Muncie 4spd) 68 RS Camaro 71 K20 BBC & granny 4 speed 95 2500 4x4 17 HD2500 4x4 Want => 67 C10 short bed w/ Manual Tranny |
02-23-2020, 07:03 PM | #2 |
Re: Water temp sensor
Found
Auto Meter
02-23-2020, 08:44 PM | #3 |
i drilled and tapped the pass head to npt and use a standard sender
02-24-2020, 07:08 AM | #4 |
Another off-the-shelf" option, is to use the 1998-2002 Camaro/Firebird temp sender. This has three pins. Two pins go to the ECM like normal. The third pin goes to your temperature gauge. As far as I know, this sender is compatible with any of the LS computers. The sender is also compatible with the 80's squarebody gauge. I don't know about other years. If the ohm specs match up with your temperature gauge, this would be the smoothest and most elegant solution.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
02-24-2020, 08:44 AM | #5 |
Yeah..I used a mechanical sending unit though
02-24-2020, 10:49 PM | #6 | |
60-66 Nut
That sender will not work with the factory temp gauge in the OP's '63 GMC
02-25-2020, 01:31 PM | #7 |
Figured it might not. I thought I'd mention it to cover all bases, though.
