01-17-2018, 12:25 PM | #1 |
Manual 465 to 90v20 Burb q's
So my friend wants to swap manual clutch setup, 465/205 into his 90 3/4 4x4 burb with a 400 and vss. I told him that I would love to help, but I have never done this swap. I have done the hydro swap and it was not too bad.
I am thinking the clutch linkage bracket could be the most pita thing to do. Any tips or pointers?I |
01-17-2018, 01:23 PM | #2 |
Re: Manual 465 to 90v20 Burb q's
Pretty sure the square body still had mechanical linkage in 90. Find a truck with all the goodies under the dash and install.
what's going to happen to the existing transmission and t-case? |
01-17-2018, 02:26 PM | #3 |
I know the pieces fit
I have that bracket. Let me find it and I can get some measurements for you. I don't think it would be hard to make from scratch.
01-17-2018, 08:35 PM | #4 | |
I think the first yr for Hydro clutch for 83-84. I used a dually one as a donor for another swap. It was easier without the linkage. The trans has no reverse. Not sure. |
01-17-2018, 08:43 PM | #5 | |
I have 465/205 early style Pedal Assembly and Z bar linkage from pedal a 78 k20 frame with a bracket and linkage Early Flat trans crossmember and t case skid He is offering up a 74 K20 350/465/205,with a Dana 44/14bff that runs and drives as a payment with current reg. |
01-18-2018, 10:55 AM | #6 |
I misunderstood, I thought you were missing the bracket. When you said it's going to be the worst part of the swap, you meant locating the bracket on the new frame?
01-18-2018, 07:24 PM | #7 |
85 is first year of the hydro clutch.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
01-19-2018, 01:08 AM | #8 | |
I have a bracket. I meant getting the bracket on. Would one have to lift the body off the frame a bit to drill the mounting holes? |
03-10-2018, 09:55 PM | #9 |
Well my bud decided to stick with the manual setup. Potentially down the road, he is considering the Novak hydro retrofit.
He dropped it off a few days ago and since the weather is shot and we are still amassing parts. I most likely won't start for a few more weeks. This will give me the time to get some needed parts ready. So, what I have. 465/205 10 spline input, twin stick rails, 30 spline front output. Pedal assembly with z bar and brackets. What I need to get for the swap 465/205 bolt in floor hump(optional & needs to be cut out)$80 Clutch kit #04-902 Flywheel for the newer crankshaft #lwf201 Starter. #Ns3838 Vss conversion for the 205 output. Behemouth Drivetrain $300 Driveshafts. $800-1000 Now there has been some discussion on weather or not he wants me to just leave the column in park and not wire in a clutch start switch. He wants to just leave it, but he has little boys... I think I am just going to wire in the pedal switch. I would hate to hear about it later and someone got hurt. Pretty nice looking truck, I actually had the opportunity to get this burb before my bud got it. It was for sale for $400 with no moving gears. He put a vacuum modulator on it and got forward gears only. |
03-10-2018, 09:59 PM | #10 |
And boom... Just like that. Everything is on hold until I find out if the headers will work with the mechanical linkage.
Dang it. I think they are thorely tri's. |
03-18-2018, 01:30 PM | #11 |
They would work fine if you ran the factory hydraulic clutch setup for that truck.
86 Chevrolet K20/30 Suburban - 8.1/NV4500/NP205/Dana 60/14 bolt FF, build in progress 73 Formula - 400/Doug Nash 4+1, resto on hold 86 Chevrolet K30 3+3 - 350/TH400/NP241, Air Force/Forest Service Rescue Truck, for sale 01 Ram 2500 - 5.9L Magnum, daily driver 91 BMW 325i - Chumpcar series racecar |
03-18-2018, 10:28 PM | #12 |
Correct. He doesn't have the cash for it.
I found a whole 88 k5 donor, but he opted out. He pays my time, so I let him decide. I tried to explain all the benefits. The blazer even had a tilt column and bench seat. It was mechanically sound with a rotten body. Guy was asking $1500. Even passed smog. |
03-18-2018, 10:30 PM | #13 |
The owner said the headers had holes in them so he had planned to change them out.
Manifolds are on order. |
