07-09-2018, 01:33 PM | #1 |
Replacement clutch pedal for 87
The pin for the clutch master cylinder rod is wasted. Does anyone know where I can pick up a replacement pedal or pin?
Optionally I have thought about pressing out the pin and threading the hole and using a bolt and cutting off the end of the rod and threading it and installing a spherical joint. Thoughts?
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find 87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4 |
07-10-2018, 04:47 PM | #2 |
Re: Replacement clutch pedal for 87
i welded mine up and filed it back to round.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
07-10-2018, 10:52 PM | #3 | |
1-1/4 long and use a locknut to button it up. |
07-11-2018, 11:43 AM | #4 | |
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find 87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4 Last edited by DieselSJ; 07-11-2018 at 12:17 PM. |
07-11-2018, 02:16 PM | #5 |
I see that. Some quick Google search didn't find that size. However, I KNOW they exist as I bought 2 of them sometime in the past. I just gotta figure out where. Might have been Speedway or Grainger. I'll try to find em and let you know
07-11-2018, 06:36 PM | #6 |
Looks like new master cylinders all come with rods, so I'm going to let this die. Now I just need to find a replacement pin for the pedal. This is where I may be going with a bolt. Tractor supply has some nice thick wall nylon sleeves so that may work its way into the setup also.
07-11-2018, 06:50 PM | #7 |
you'll have to weld the bolt in, you can't tighten it up its got to be able to move.
07-12-2018, 01:48 PM | #8 |
Bronze sleeve. I can tighten against it.
