04-15-2015, 07:09 PM | #1 |
thoughts on rear disc problem
So I did a rear disc conversion on my 31 crew it got 3/4 ton calipers in the rear and new crossed drilled an slotted rotors and hawk pads on all 4 wheels I also put a disc disc master cylinder and also disc disc prproportion Valve . My problem is im getting alot of squeaking from the rear brakes and the rear has more brake dust the truck stops awesome now but the constant sqeeking is driving me nuts. At first i thought maybe the pads but the front has the same and no noise any thoughts why ?
04-16-2015, 06:00 PM | #2 |
Re: thoughts on rear disc problem
Sorry 91 crew
04-17-2015, 01:23 PM | #3 |
Are you running new rotors? If not, you might have yours machined to remove the glaze on them.
77 C10, 6.0LS/4L80E, 3:73 12 bolt. Boss 338's 20" x 10" w/ 285/50/20 rear. 20" x 8.5" w/ 245/40/20 front. Vintage Air. Full Autometer gauges recessed in factory bezel (Thanks bigblock73!) Gm Storm Grey Metallic paint "Cool ain't ever cheap and cheap ain't ever cool" |
04-18-2015, 04:40 AM | #5 |
Yes all 4 rotors are new. So if its too much rear bias even with the disc disc prop valve what are my options ? Adjustable prop valve ?
04-18-2015, 04:40 AM | #6 |
Post Whore
interesting, let us know when you figure it out
04-18-2015, 08:55 AM | #7 |
I know the pieces fit
I did not know disc was a factory option on 3/4 ton trucks in 91. Or was it? When you say you got disc disc MC and prop valve installed are they factory parts or aftermarket?
04-18-2015, 11:31 AM | #8 |
Lots times its the piston on the back pad not the disc we used lube them but most pads have a plate on back now.
83 c10 long Box Daily Driver 90 Jimmy parked 98 Road King/ 06 Road Glide In memorium 63 impala SS/ 65 Chevy Panel 65 GMC Short Box/ 68 Camero |
