05-17-2020, 11:24 AM | #1 |
Brakes: Drilled and slotted?
I've found some affordable options online, but all seem to be 4wd and I'm just wondering if they will possibly fit on a rwd truck...curious if the hub sizes are that unique in comparison with each other.
Thanks for advice, it's greatly appreciated! '85 c10 rwd 350/350
Rest In Peace:Mikhail {Mickey Rooney} Alpha 2/5/13 Omega 7/22/14 10:28AM I love you tremendously and outragiously Superpuppi Thai Ridgeback...The most intelligent dog known to me. Don't mess with my truck, my momma or my money...not necessarily in that order. ©Stand for something or fall for anything. [LIST][*]'98 Bourbon St. Brawl ©2010
05-17-2020, 11:48 AM | #2 |
Re: Brakes: Drilled and slotted?
Four wheel drive is 6 lug, so you got that working against you.
05-17-2020, 12:48 PM | #3 |
and 2wd to 4wd HUGE difference in front spindles and size of bearings and spacing .
and took me longer to typethis than to find drilled / slotted for 2wd trucks . https://www.rockauto.com/en/catalog/...hub,rotor,1896 not sure were you were looking ? ? ? good luck on your choices . there isa lot out there to pick from .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
05-17-2020, 01:25 PM | #4 |
At the body shop.
Put their stuff on my obs crew cab. Stops like a new truck, better than new actually
" That didnt make it any newer " " Dont antique the equipment " |
05-20-2020, 06:38 AM | #5 |
The Peacemaker
R1 Concepts has some nice cross-drilled and slotted brakes for C10’s/20’s. I have them on my 79 and also used R1’s on my Trailblazer SS. Great brakes and extremely affordable.
1978 Chevy 2wd Stepside aka "Audrey" Cordova brown with mandarin guts 79k original miles & being restored 1979 Chevy 2wd Short Wide aka "Emma-Jayne" Cordova brown with mandarin guts 2019 Chevy Tahoe LT Previous rides: -2002 Firehawk T/A, 2006 Trailblazer SS AWD, 2014 GMC Sierra RCSB, 1971 2wd Blazer, 1996 SNB, 1997 2dr 2wd Yukon, 2001 Silverado RCSB, 2011 Silverado Z71 4x4, 1982 2wd Blazer, 1997 2dr Tahoe, 1970 Chevelle SS, 1972 2wd Blazer, 1986 Silverado Stepside, 1995 S-10, 1985 Silverado SWB. |
05-27-2020, 12:22 PM | #6 |
The slotted rotors are no good for winter driving any salt will rust them maybe some cracking. ( only for summer driving and the holes need to be cleaned for time to time to keep them in good shape.)
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
05-31-2020, 09:54 PM | #7 |
At the body shop.
Except they're zinc plated.
