10-13-2014, 03:00 PM | #1 |
69 4 door long bed k30
okay im wanting to start my next project build soon and i want it to be unique. my plans are to build a 69 crew cab long bed truck out of a 69 suburban. im wondering if anyone else has done this yet and would be willing give me some pointers like if it would be easier to use a different frame or just lengthen this one. im also going to be converting it from 2wd to 4x4 which is why im leaning towards finding a new frame but i would kind of like to keep the orignal frame so that i could use the stock gas tank underneath the truck and either free up the space behind the seat or incorporate dual tanks. my plans are to run a 14ff rear d60 front sitting on 35s. i was thinking of putting a old 2 stroke 6v53 detroit diesel and an allison automatic to be really cool but i cannot find one any where where i live so i think im just go with a lq9 6.0. and i was thinking of running the sm465 behind it thinking it would be cool because i have never seen it but then again i want this thing to be a super hauler and able to fly down the interstate at 80mph with another truck on trailer behind it which makes me want the over drive of the 4l80e. plus an automatic would just be more convenient. also was wondering if any body has tips on adding the 4th door to the drivers rear side and also i know i will need to change the rear door tops to the rounded ones to match the back of the truck cab and was wondering if anyone has ever rounded off the front doors to match and if it would be worth it i have only seen pictures of the 4 doors built still use the square front doors and rounded back and it looks good im just looking for opinions and suggestions. the suburban that i am looking at already has a newer 98 dash board in it and looks really good i will be posting pics when the project gets started just wanted to get some opinions before i get started. this is going to be my toy hauler/neck breaker. all input appreciated thanks wasn't sure whether to post here or in the suburban forum but the build is going to be a pick up in the end so i figured this will be the best place.
10-13-2014, 09:41 PM | #2 |
SWB 4x4 Collector
Re: 69 4 door long bed k30
I will say that it is a lot of work. I'm working on one now, and am just about to finish the fourth door fabrication. As far as the rounded front door, I wouldn't do it, it will look odd, as in it won't flow as well from front to back, but that is my opinion. You got to do what you want when building it. Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
10-13-2014, 11:44 PM | #3 |
Do you have any pictures of the 4th door your building? And what are you actually using for the door a front door off of another suburban or pick up?
10-14-2014, 03:38 PM | #4 |
SWB 4x4 Collector
There is a link to my build under my post in the blue highlighted words. Trevor
10-14-2014, 05:28 PM | #5 |
Check out my build. if you want a 4X4 it would be better to start with one and stretch the frame. I had to stretch my frame 24.5" and I used a short bed.
http://67-72chevytrucks.com/vboard/s...d.php?t=596036 |
12-21-2014, 09:55 PM | #6 |
How hard is it to find an original crew cab? I have only seen one and I cannot find much info on how many were produced. Personally I am a suburban fan though. Good luck with the build.
12-21-2014, 11:13 PM | #7 |
The crew cabs where custom made for the railroad and who wanted to have one built. if you google (1972 crew cab) you will find pictures of the originals cabs they look like 2 cabs welded together. there is a guy in Washington building crew cab with 4 doors they are pricy at $15,000.00 for a cab ready for primer. Check o0ut this thread http://www.67-72chevytrucks.com/vboa...d.php?t=319781
12-21-2014, 11:28 PM | #8 |
Here is the truck I ran across...is this original or custom? I was not able to stop and take a closer look at the time. This pic is from google street view.
12-21-2014, 11:47 PM | #9 |
It is made from a suburban it has a high roof with the 4th door added. Most mods they cut the roof line down like the truck cabs.
Tags |
4 door, adding 4th door, crew cab, long bed, suburban cab conversion |
