Old 02-15-2018, 09:41 PM   #1
NoNeck
NoNeck's Avatar
Upholstery Ideas After Removing Gas Tank Behind Seats
I am looking for ideas to upholster the area behind the seats after the gas tank has been removed. I can work out the flat areas using 1/16" Luan paneling, but I'm not sure how to round out the cab corners for a nice clean look.
Thanks,
POP
2016 RAM Laramie HEMI
1966 Fairlane GT/A, 390/335 HP
If it costs you a dollar to make a friend, KEEP THE DOLLAR.
If it costs you a friend to make a dollar, KEEP THE FRIEND.
NoNeck is offline   Reply With Quote
Old 02-15-2018, 09:50 PM   #2
harpo231
harpo231's Avatar
Re: Upholstery Ideas After Removing Gas Tank Behind Seats
1/2 " wire mesh plastic coated....
Stan
67 swb BLU MULE
posted via flip-fone
harpo231 is offline   Reply With Quote
Old 02-15-2018, 10:42 PM   #3
darrellyates
Thanks,
POP
I replaced mine with a custom sub box the size of the tank, using the same mounting bolts and a shallow mount sub. I then used MDF and cut it to the shape of the curved corners, and incorporated storage openings for the jack and a fire extinguisher. You can then cover it with material, or carpet, or felt, or whatever... Will try to post a pix.
darrellyates is offline   Reply With Quote
