02-02-2018, 11:10 AM | #1 |
Putting steering wheel lock plate back in - help
Anyone have any tricks for putting the steering wheel lock plate back in?
I pulled it apart to replace my ignition lock cylinder and now I am having a difficult time pushing the plate past the ridge to install the C clip/lock. That spring under it aint no joke or, I am losing my strength in with age!
Frank (Hilo, Hawaii) Trucks, Tacos, and Beer go together like Peanut Butter and Ladies! 85 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=760383 67 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=489298 79 K5 Blazer SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=657461 |
02-02-2018, 11:15 AM | #2 |
Re: Putting steering wheel lock plate back in - help
I use one of these:
https://www.summitracing.com/parts/o...SABEgKIRfD_BwE They are sold at most parts stores. |
02-02-2018, 11:15 AM | #3 |
There is a tool that compresses the plate to install the ring. Without that tool, its a nightmare to fight.
02-02-2018, 11:39 AM | #4 |
There is one or 2 wide splines on the shaft that needs to match the teeth on the plate.
02-02-2018, 12:12 PM | #5 |
Yup, there is a master spline. You need the tool, it pulls up on the shaft along with pushing down the plate
02-02-2018, 04:37 PM | #6 |
Thanks everyone... I wrestled it last night for about 30 min and 2 beers (beer strength) and could not get it in far enough to set the clip. I will check with my local parts store for the tool. Figures there is a special too for EVERYTHING.
Thanks!!!
02-02-2018, 08:02 PM | #7 |
Loan a tool from autozone. That’s what i did. Worked like a charm
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart My build 2008-2016. http://m.imgur.com/a/bURrE |
02-02-2018, 09:30 PM | #8 | |
I appreciate all the help!!!
02-02-2018, 10:24 PM | #9 |
Done and done
02-11-2018, 07:18 PM | #10 |
Or make your own tool [IMG] [/IMG] http://bowtieguy.proboards.com/thread/1227/tilt-column-tear-repair-renew
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
