Old 02-06-2019, 01:26 AM   #1
BIG ORANGE
BIG ORANGE's Avatar
Going aftermarket with radio
The truck has a equalizer to, can I disconnect the head unit that the radio and equalizer is plugged into and just do away with all 3 items.
I'm new to these 90s trucks. Also removed the busted up dash out of my 91 and hoping to install a 94 dash out of a donor truck....
Thanxs
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
Old 02-07-2019, 09:56 AM   #2
Tricky03
Tricky03's Avatar
Re: Going aftermarket with radio
Hello. It's been a while since I've done one of the early style trucks but yes, you can eliminate all the factory equipment and just use aftermarket. Actually, you have to eliminate the the factory equalizer in order for the speakers to work with an aftermarket radio. I do remember it was a pain in the ass to remove because it's really tight behind the dash. You'll end up with a nice pocket for storage where the EQ was.
Best thing to do it stop by a car stereo shop and either have them do your install or at least tell you what has to be done. You'll need the complete install kit with all harnesses, pockets and dash kit. Be prepared, it's a lot of work to do by yourself or will cost a bit more to have them do it...
Tricky03 is offline   Reply With Quote
Old 02-07-2019, 11:31 AM   #3
Jeepwm69
I've never seen an aftermarket radio in an 88-94 truck that didn't REQUIRE removal of the equalizer. That's where the aftermarket radio will go. I don't think anyone makes an aftermarket radio that fits where the stock radio comes.
Jeepwm69 is offline   Reply With Quote
Old 02-07-2019, 12:09 PM   #4
Tricky03
Tricky03's Avatar
Yeah, my post is a bit confusing. The pocket replaces the factory radio and the aftermarket stereo replaces the factory EQ.
Old 02-07-2019, 02:11 PM   #5
Stormin08
Stormin08's Avatar
take a peak at my dash, i just made a cover plate for the EQ spot.
Stormin08 is offline   Reply With Quote
Old 02-08-2019, 10:13 PM   #6
BIG ORANGE
BIG ORANGE's Avatar
I did a complete dash swap and the 94 already had a aftermarket radio installed in the dash
I just need 1 of those pocket to go in place of where the original radio was located.
Old 02-09-2019, 10:05 PM   #7
BIG ORANGE
BIG ORANGE's Avatar
Thanxs for the input, got the piece I needed today....
Old 02-15-2019, 05:07 PM   #8
diveplane
Thanxs
i replaced mine with a nice face pop off unit plenty kits on ebay at great prices.
diveplane is offline   Reply With Quote
Old 02-23-2019, 01:04 AM   #9
BIG ORANGE
BIG ORANGE's Avatar
Got the kit, and removed the bad factory unit an installed the JVC
