Old 03-06-2018, 07:12 PM   #1
jorgensensc
jorgensensc's Avatar
Gen V LT L83 frame stand/Motor Mount question
Hey guys,
I have been reading up, but haven’t seen the differences addressed. I’m putting a L83 in a 68 c10. I want to retain the vacuum pump. I am using a kwik performance power steering bracket w/high mount Sanden ac compressor.
If I use dirty dingo motor mounts with the SBC frame stands, does it make a difference if I use the stands in the 6 cylinder position or the 8 cylinder position? Will it clear the vacuum pump? Will one position clear the stock truck oil pan on the crossmember?
If I use dirty dingo motor mounts with squarebody frame stands with clamshells, on the 68 crossmember, the vacuum pump should clear, but will I still have to notch the crossmember if it’s not a squarebody crossmember?
On the dirty dingo websight it says the vacuum pump won’t clear on 68 stock mounts, but doesn’t delineate between 8 cylinder or 6 cylinder position frame stands.
It also says the vacuum pump will clear with on square bodies, but says you must notch the crossmember with the stock l83 oil pan.
I also know ICT sells brackets too, but haven’t figured out if they can be mismatched around easily.
Just seeing if anyone has used any of these combos?
Thanks for the help all!
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 03-06-2018, 10:35 PM   #2
Clyde65
Clyde65's Avatar
Re: Gen V LT L83 frame stand/Motor Mount question
I didn’t think you could keep the vac pump with the power steering bracket? What’s your idea for fuel??
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 03-06-2018, 11:25 PM   #3
jorgensensc
The kwik performance setup puts the power steering on the passenger side down low, and puts the Sanden compressor mount up higher. I’m not sure yet on the fuel system. I used the in tank fuel pump from a 92-94 s10 blazer with MFI and the corvette filter/regulator for my current 6.2 swap. It puts out 80 psi stock. I may do the same again with maybe an adjustable regulator. I’m just not sure yet. I don’t know if you HAVE to have a PWM Fuel pump.
Old 03-07-2018, 07:32 PM   #4
Clyde65
Clyde65's Avatar
I just had my programmer come by to turn off the VATS AGAIN! And he made it so the fuel pressure I currently have from my external pump works without a regulator.
Clyde65
Rebuild of Clyde
support our troops!
Old 03-10-2018, 02:52 PM   #5
jorgensensc
Is it a PWM type fuel pump?
Old 01-12-2019, 05:01 PM   #6
howell57
Doing the same with a LT1 L83 engine. Was told to wait till first of year for a whole bunch new products for the L83. That Kwik unit for $499 with power steering pump seems the best way to go without moving a whole bunch of items. Where are you getting your radiator from?
howell57 is offline   Reply With Quote
Old 01-29-2019, 06:25 PM   #7
howell57
Dirty Dingo rep pointed out that they have a disclaimer at the bottom of their L83 engine mounts that says you can't have the vacumn pump there because it will interfer with the motor mounts.
Old 03-01-2019, 12:35 AM   #8
f.flujan
Howell57 sent you a pm
f.flujan is offline   Reply With Quote
Old 03-01-2019, 01:14 AM   #9
howell57
Cornerstone
Mitch Vannatta (SwapTime) did my harness. You can watch him on Youtube, just imput swapTime in Youtube search.
Old 03-02-2019, 11:16 AM   #10
cornerstone
cornerstone's Avatar
Originally Posted by howell57 View Post
Cornerstone
I'm glad to see he has taken this on full time! Lovin his new logo too, it reminds me of the Gran National experimental logo from the 80's. Anyone doing this swap NEEDS to subscribe to his channel and learn a bunch of stuff he has already figured out.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 03-06-2019, 09:55 PM   #11
f.flujan
Jorgensensc how is ur build going?
Old 04-02-2019, 02:55 PM   #12
GreyGhost85
interested in progress as well
1971 C10 L83/6L80E Build
GreyGhost85 is offline   Reply With Quote
Old 04-12-2019, 09:53 AM   #13
Daaaanz67
Subbed.
Daaaanz67 is offline   Reply With Quote
Old 04-12-2019, 11:37 PM   #14
siggyfreud
siggyfreud's Avatar
From what I've read people end up with issues when they move away from PWM on the LTs.
I can't remember what magazine did it, but they said to use Aeromotive's Phantom in-tank pump that is compatible with PWM to feed the LT's onboard high-pressure direct-injection pump.
https://www.aeromotiveinc.com/produc...si-6-10-depth/
siggyfreud is offline   Reply With Quote
