Old 02-05-2008, 02:21 PM   #1
1969stepside
1969stepside's Avatar
1969 gas tank relocation
i own a 1969 c-10 stepside and i have bought the brothers gas tank relocation kit and i have heard that i cant do this because the truck has coil springs can i do this and can i lower the truck and the truck has a wood bed
Greater love hath no man than to lay down his life for a friend.
Members i Have met
Earl Slick68
1969 Stepside Build thread
http://67-72chevytrucks.com/vboard/s...=1#post4253546
Chevy Trucks the longest lasting most dependable trucks on the road
1969stepside is offline   Reply With Quote
Old 02-05-2008, 02:38 PM   #2
AuggieStyle
AuggieStyle's Avatar
Re: 1969 gas tank relocation
wow i hope that is not true because i just bought one and i asked that very same question, stepside wood floor. i have been wondering bout the taylor frame mount battery tray i purchased that looks like it is gonna be a tight fit.
AuggieStyle is offline   Reply With Quote
Old 02-05-2008, 10:08 PM   #3
69c10step
69c10step's Avatar
I have never heard of any issues, but who am I. So,..... TTT
'69 short step with dreams of being a hot rod
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
69c10step is offline   Reply With Quote
Old 02-05-2008, 11:39 PM   #4
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
1969Stepside,
Check out my post from today about the Marker Light Fill w/ Rear Tank. I used a Blazer Poly Tank (Previous Owner had it). I checked out the one from Brothers - looks the same - 45 degree fill neck on the D/S.
I like this because I do not want to get overfill gas on my nice wood bed.
BTW, I am going to bag my truck. We just did a Leaf Spring to Trailing Arms Swap.
Good Luck
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 02-06-2008, 01:19 AM   #5
tbags
tbags's Avatar
Originally Posted by myoldchevytruck View Post
1969Stepside,
Good Luck
What year blazer does it come out of? Will it bolt right up?
67' C-10 Project Truck
Clinton Township MI
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=287690
tbags is offline   Reply With Quote
Old 02-06-2008, 02:22 AM   #6
myoldchevytruck
tbags
The tank was from a 69' blazer. Vendors/Board Members such as GMCPauls and Wes at Classic Heartbeat sell this tank, so it's readily available.
BTW, this is a bolt in item. It's actually a replacement for the behind the seat tank. This one installs between the frame rail and cross members right behind the rear axle.
The kit comes complete with mounting straps and hardware. The holes are already in the frame. Filler necks are more of a custom thing, depending on where you want to fill the tank.
Good Luck
Harry
3/6 Drop
Krue's FAQ Page
Vendors
Old 02-06-2008, 03:25 AM   #7
tbags
tbags's Avatar
tbags
Good Luck
I was going to get the parts from a local vendor so i was wondering on the year. I manage a auto repair facility in michigan so i get wholesale from local vendors. is there any other specific infor i may need?
Thanks for all your help
Clinton Township MI
My Build Thread
Old 02-06-2008, 05:45 AM   #8
1969stepside
i bought my kit from brothers and it is a blazer tank
Members i Have met
Earl Slick68
Old 02-07-2008, 12:13 AM   #9
kulturekat
kulturekat's Avatar
i was reading the link and it said you have to add a fuel line from the cab to the tank which i knew thats kinda common sense but my question is did it come with that or did you rob it from a nother truck that had it already or what did you do for yours?
kulturekat is offline   Reply With Quote
Old 02-07-2008, 12:43 AM   #10
myoldchevytruck
kulturekat,
I don't believe (almost positive) the kit does not come with that fuel line. I was thinking about running my fuel line like that - from the cab to the back but I think the travel is too long. Thats a long way for the gas to travel without alot of pitch. I could be wrong, but I was think that there would always be gas in that long line.
Harry
3/6 Drop
Krue's FAQ Page
Vendors
Old 02-07-2008, 12:46 AM   #11
kulturekat
kulturekat's Avatar
so then how would you run the gas line i know you have a short bed but i have a long bed.
Old 02-07-2008, 12:56 AM   #12
myoldchevytruck
There's quite a few threads on this, I'll see if I can track a few down...Anyone else, feel free to chime in on this.
Harry
3/6 Drop
Krue's FAQ Page
Vendors
Old 02-07-2008, 01:10 AM   #13
kulturekat
kulturekat's Avatar
thanks if you find it first thatd be awesome ive been doing a search but havent been able to find anything on. also was looking for what people did on the filler neck with out doing it behind the tail light or side marker. i know they have caps that fit flush in the bed thats what id like to do. ill keep searching. also wanted to see of other alternative to lines like can i run different aterials or just the steel lines or whatever. thanks for your help.
as soon as i can find info on the fuel line im gonan put my order in for one of those.
Old 02-07-2008, 01:31 AM   #14
myoldchevytruck
Here's a thread that is currently posted. Board Member - tdave00 (Scroll down till you see his post) shows how another Board Member - SatcoJim did his fuel fill in his fleetside bed. This is nice:
http://67-72chevytrucks.com/vboard/s...d.php?t=277343
He shows his fill in the middle of the bed, probably a fuel cell but I am sure this could work with the blazer tank. Be creative.
Here's a couple of other ideas for fleetsides. I'll track the threads down.
One had the fill cap in the rear D/S Stakebed hole with a Cool Cap from Air Ride Technologies
Another had a flip down rear D/S Tail Light.
Another had a fuel neck fill coming through the rear D/S fender
Harry
3/6 Drop
Krue's FAQ Page
Vendors
Old 02-07-2008, 01:45 AM   #15
kulturekat
kulturekat's Avatar
i love the flushmount cap from cool cap. thats the route i was thinking about going. thank you so much for your time spent.
i already shaved my side markers on front and rear so i cant put it in there haha.
Old 02-07-2008, 02:56 AM   #16
myoldchevytruck
Charles,
Here's a few more ideas
This is John Fabris's Truck. No wonder it was Truck of the Month.
http://67-72chevytrucks.com/vboard/s...d.php?t=211579
Here's is Shify's idea for a poor mans no weld fuel cap
http://www.67-72chevytrucks.com/vboa...d.php?t=250995
Here's Krue's (Forum Staff) FAQ Index Thread with more great ideas and tips from various Board Members
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
Harry
Harry
3/6 Drop
Krue's FAQ Page
Vendors
Old 02-07-2008, 05:54 AM   #17
Putter
More Cowbell....
Putter's Avatar
I went to the junk yard and got the fuel line from under a long-bed 1500 work truck (chevy-88-98). I kept the inline fuel filter and just cut the line to length. A few extra bends and violla.....blazer tank under a short-bed stepper with side marker filler.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 02-07-2008, 06:47 AM   #18
Psycho71
Psycho71's Avatar
While we're on the subject here.
Is anyone else having starvation issues with the rear blazer tank relocation? I did this on mine a while back, and since then have noticed the fuel filter will not completely fill up. It always just has a little gas in it.
With my Holley carb, it never was an issue. But right before I tore my truck apart, I replaced the holley with a q-jet (just to see if it made a difference on mileage, yes but small) and it will starve at about 4000rpm in second gear. I mean it'll fall on it's face and stumble until I let off, then it'll go again. I'm assuming at this point it's because the q-jet doesn't have the storage capacity that the holley does (bowls). But then, there have been a few times with the holley that I have done WOT runs for over two miles (don't tell DPS, lol) with the holley, and no starving there either. I'd think in that distance it would use up what's in the bowls. And it never starves when driving normally with either carb.
FYI, My fuel filter is before the new stock mech. pump. I ran all new 3/8 steel lines from the tank to the pump. Vent is good/open. All seems to be in good working order.
Any ideas?
I'm seriously considering installing an electric pump under the truck since the mech pump is actually above the fuel level of the tank. I know this will fix it, just curious if anyone else has this issue.
Jay
If a hammer doesn't fix it, you have an electrical problem!
Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels!
Psycho71 is offline   Reply With Quote
Old 10-26-2009, 12:52 PM   #19
71tahoe
71tahoe's Avatar
Any ideas?
Jay
A diaphram type pump should be able to pull the fuel the vertical 12" to the pump with no problems unless it is pulling against a vacuum in the tank. Also under hard acceleration the weight of the fuel can act against the pump. 3/8 line is a good idea but the bigger the line, the more fuel weight.
Have you checked the filter in the carb to see if it is clogged?
71tahoe is offline   Reply With Quote
Old 01-17-2016, 01:37 PM   #20
Starykon
Starykon's Avatar
Hey guys,
Has anyone done a tank relocation keeping the original filler location? I just got a 67 lwb, and want to mod the interior, which will require moving the tank out of the cab. I like the look of the filler as is, and I'm planning on pulling the bed off altogether and doing a wood flatbed, so relocating the filler into a fender or side marker is a no go. Any advice would help a lot. Thanks!
Starykon
Starykon is offline   Reply With Quote
Old 02-07-2008, 06:57 AM   #21
kulturekat
kulturekat's Avatar
hey putter what size fittings was the line you snagged
Old 02-07-2008, 07:09 AM   #22
67ChevyRedneck
67ChevyRedneck's Avatar
Here's what I did, it's a blazer tank as well... with coil springs
http://67-72chevytrucks.com/vboard/s...d.php?t=197895
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 10-26-2009, 10:58 AM   #23
72K20
Slow Old Timer
Can I ask what you got the donor gas door and filler assembly from? That is exactly what I want to do to my Stepper!
72K20 is offline   Reply With Quote
Old 10-26-2009, 11:49 AM   #24
myoldchevytruck
Looks like its from a newer style Chevy S-10
Harry
3/6 Drop
Krue's FAQ Page
Vendors
Old 02-07-2008, 11:51 PM   #25
Putter
More Cowbell....
Putter's Avatar
Uhhhh....Got me?!?!?! I started at the cab and connected it to the stock metal line with a rubber 'splice', and did the same at the tank. No actual fittings except at the filter....and that is stock 88-98.
