Old 12-16-2018, 01:49 AM   #1
drivewaycustoms
drivewaycustoms's Avatar
87 R30 running rich, any suggestions
I have an ‘87 R30 dually,454,400, fuel injected(tbi) . When I start it up it the exhaust gas smell is so rich that it’ll make your eyes water. Any suggestions? I’ve already changed the O2 sensor, throttle body gaskets and coolant sensor.
87 Crewcab Dually
66 Cadillac Sedan deVille
55 Chevy Belair
33 Plymouth sedan
03 S-10
86 S-10 Blazer
IG drivewaycustoms
drivewaycustoms is offline   Reply With Quote
Old 12-16-2018, 02:47 AM   #2
GIZZ
GIZZ's Avatar
Re: 87 R30 running rich, any suggestions
Map sensor? A very plugged air filter? Spark plugs all look the same? Could take temp reading alongthe exhaust manifolds to see if all the cylinders are firing.
GIZZmotorsports on YouTube & my panel truck build
'69 c10 panel, '75 c35 flatdeck car hauler
GIZZ is offline   Reply With Quote
Old 12-16-2018, 11:59 AM   #3
drivewaycustoms
Thanks. I’ll check for the sensor and check the cylinder temps. The air filter is new.
87 Crewcab Dually
55 Chevy Belair
33 Plymouth sedan
03 S-10
86 S-10 Blazer
IG drivewaycustoms
Old 12-16-2018, 01:06 PM   #4
4x4k30
4x4k30's Avatar
you need to check the fuel pressure regulator on the throttle body it will cause it to run rich and check the t/b gasket and t/b for any vacuum leaks .
4x4k30 if trouble was money i would have plenty
4x4k30 is offline   Reply With Quote
Old 12-16-2018, 10:24 PM   #5
drivewaycustoms
Thanks, I’m gonna pick up a rebuild kit, they’re cheap and shouldn’t take long to do.
87 Crewcab Dually
55 Chevy Belair
33 Plymouth sedan
03 S-10
86 S-10 Blazer
IG drivewaycustoms
Old 12-17-2018, 02:22 PM   #6
kwmech
Vacuum line to the MAP sensor...check for cracks. Also the water base plate under the TBI was famous for blowing the gasket out on the vacuum side of the EGR port
